Question about Siemens Gigaset 4015 Cordless Phone
My base set was hit by a power surge
I think a had a power surge and my base set is not working. the handset is working because I tried it on another base set
Hi, I have a DECT2085-3 base with 3 handsets. I would like to add another handset. I bought two used handsets and would like to register them to my original base. I am having trouble with the selecti
In the instructions you need to find how you Sync the base and add that number phone to the base. All have different ways so try the company website on google.
Dec 09, 2014 | Uniden DECT2085-3 Trio Cordless Phone
We have a telephone handset and base the Gigaset A265 which is not ringing in the house but going straight to our message system on our computer via our internet provider orange. We can call out but are...
Hello.
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes. That way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Sep 01, 2011 | Siemens Cell Phones
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Hello.
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the base:
Jul 25, 2011 | Uniden Cordless Phone
My handset won't charge
Try charging it in a different cradle if you have more than one handset.  This has happened to me where a particular base will not charge a particular phone.  Once charged elsewhere the problem resolved.
Feb 14, 2008 | Motorola Mobility MD671 Cordless Phone
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
My siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Dec 08, 2007 | Siemens Gigaset 4000 Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Siemens Gigaset 4015 Cordless Phone Logo
91 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
