Question about NEC IT3640D Printer
Does nec it3640d have mechanical meter - NEC IT3640D Printer
I have a nec vt570 projector and it has gone into bypass mode because I let the lamp go to long. I've replaced the lamp but can't reset the hour meter.Is there any way to reset without the remote
Switch on the projector in standby mode.
press the HOLD button on the remote for 10 secs.
the projector will come out of protection and you are good to go!
ensure that u replace a new lamp!
This can be done only with the NEC remote!
Jun 04, 2015 | NEC Office Equipment & Supplies
Entering service mode on an nec 2840
Ok, I realize this machine is already EOL, but if anyone else runs into this issue, I found the answer here.
  1. Press the "Utility" button
  2. Press the "Access" button
  3. Press * four times
  4. Press the "Maint" soft button on the touch screen
  5. Press the "Service Mode" soft button on the touch screen
Once you are in there, you can reset the admin password by pressing the "Administrator # Initialize" soft button, and that will reset the admin password back to the default 00000000. This is actually for an IT3640, but evidently, this works for a few other models of NEC copiers as well.
Dec 11, 2013 | NEC It 3640 2530 3530 2840d Copier...
Need driver for nec it3640d for windows 7
VIEW AND DOWNLOAD
http://support.necam.com/Legacy/Document_Solutions/IT3640D.cfm
Nov 11, 2013 | NEC IT3640D Printer
Nec vt695
Did you unplug it before you replaced the bulb?did you touch the bulb?are you sure the bulb works?have you reset the lamp hour meter?did you replace all doors, screws and original parts?is the bulb securely in place?
Here is your manual http://www.support.nec-display.com/dl_service/data/manual/english/vt695_491_manual_e.pdf
Mar 29, 2013 | NEC VT695 LCD Projector
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
f the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
f the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 26, 2012 | Washing Machines
Message on screen-The bulb has reached the end of its usable life....and it has 97 hrs left and can't clear the message.
select Menu>>>[default]>>>[Clear Lamp Hour Meter]. do this after replacing the lamp.
below is a link to the manual. what you seek is on pgs E-30,31. Good Luck!
http://www.support.nec-display.com/dl_service/data/manual/english/vt660k_e.pdf
Sep 13, 2011 | NEC VT460 Multimedia Projector
How to reset lamp hours lt265 nec
Select the Menu [Reset] → [Clear Lamp Hour Meter] to clear the Remaining Lamp Time and the Lamp Hour Meter
Mar 05, 2011 | NEC LT265 Multimedia Projector
How to replace and reset NEC lamp LT60LP
HI
PL GO TO MENU ---DEFAULT --& SELECT CLEAR LAMP METER.& PRESS ENTER THEN SELECT YES.
fOR
M.R MUMBAI -DUBAI
Aug 28, 2010 | NEC LT60LP Projector Lamp for LT240,...
NEC VT770
Go to MENU and clear Lamp Hours meter.
Jul 10, 2008 | NEC Replacment Lamp Projector Lamp for...
Replacing new lamp
Hi - You can download the manual from the link below:
NEC vt465
Look at page E-30, make sure the cover is screwed up tight as there is an "interlock".
Most likely is the lamp hour meter needs reseting:
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 07, 2008 | NEC VT465 Multimedia Projector
NEC IT3640D Printer Logo
18 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
