Question about Denon AVR-2106 Receiver
Do you have to use banana plugs to connect speakers to avr-2106 receiver
SOURCE: Denon AVR-2106 troubles
If the surround back is turned on,on the receiver,then the 7CH stereo will activate the 2 rear,but if it's off on the receiver the 5CH on the remote will do the same. I don't know much about the unit changing from 7CH to game,rock Arena etc.that i know will happen if u press the DSP simulation found @ the 3rd. top right button on the remote.
Posted on Sep 21, 2007
SOURCE: Denon AVR-2106 high pitch tone when using video/audio inputs
Posted on Feb 23, 2009
  • 119 Answers
SOURCE: problem getting the best surround sound when watching a dvd
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Posted on Mar 01, 2009
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 2106 clicking noise
I like when a user is observant and curious. That will help immensely in resolving this problem.
What source(s) are always involved with the problem?
You imply it is observable with output video to the TV - "only when there is movement on my tv screen and it stops in still screen". That sounds like a digital pathway problem of some sort as any data errors would eventually escalate to something audible or visible to you once the hardware and correction algorhythms are exhausted. The clicking inside the receiver could be its efforts to resynchronize with a bad data stream. Hence, I'd like you to isolate the ins and outs that fail all the time and find the probable single source of the problem.
Try this: put a digital source on and select/deselect it for listening or viewing. Does it make the click in that brief time it's 'thinking' before you hear the source? That would be the 'normal' sound. My Pioneer does it once per source switch. Repeated clicking would mean it's struggling.
I'm betting you have an optical or hdmi cable that's flaky or not in tight and straight. Or, if only one extternal source is involved we follow that back.
Posted on Apr 29, 2009
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Posted on Jul 01, 2009
Connecting Speakers to Marantz NR1402
HI,
You can use banana plugs to connect speakers to the speaker post. Connect the wire to the banana plug then insert the banana plug in the speaker post.
If you serch in google with the name speaker banana plug then you will get picture of different types.
You can buy this banana plugs in any nearby electronic spare part shop. They all stock this item. Normally comes in pair ( red, black)
Ajin
Feb 22, 2012 | Marantz Audio Players & Recorders
WHATS THE MOST COMMON AND SIMPLIEST SPEAKER CONNECTION FOR THE DENON AVR 1909
Hello,the simplest and most durable is the banana plug,while the most common is simply connecting bare wire.
Feb 21, 2011 | Denon AVR-1909 Receiver
Jun 28, 2009 | Denon AVR-2106 Receiver
Denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
Problem getting the best surround sound when watching a dvd
Mar 01, 2009 | Denon AVR-2106 Receiver
Denon avr 3000 speaker B is off ,is theres a code to turn it on
I have a Denon AVR-3000 and want to turn on the B Speakers. I have hooked up my subwoofer to the B connections on the Denon since there is not a subwoofer connection. How do I turn the B speakers on without a remote
Jan 27, 2009 | Denon AVR-2106 Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Denon AVR 2106 amp failure
Does it still power up for a little bit or so with no sound what so ever?....I there is no dents in it or metal pushed in causing cracked connector boards....I can take it off you hands for a couple parts I need ...because your transformer and 2 resisters are shot and it will cost almost as much as the unit cost's.
I do have a brand new never opend $649.99 Denon AVR-788 for $365.00.
And 2 used AVR units Denon and Onkyo.....ALL HDMI
call 630 742 6587
Aug 30, 2008 | Denon AVR-2106 Receiver
Denon 2106
Try making sure the plugs are snug. Always helps me!!
Dec 08, 2007 | Denon AVR-2106 Receiver
Jan 16, 2007 | Denon AVR-2106 Receiver
Denon AVR-2106 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
