Question about Prestige Remote Start
Car alarm system will not let me start the car
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Disabling alarm system on 2000 mitsubishi mirage
this is a long shot, put the key in the driver door, turn to unlock then try to start the car, some systems disarm when the key is used to unlock the car.
Jul 05, 2012 | 2000 Mitsubishi Mirage
I have a 1994 toyota camery and it has an alarm system the kids left light oh and killed battery so we charged it now alarm is going off we dont have remote for alarm and now we cant start car. how do we...
Hello. Welcome to FixYa. Please allow me to assist you. If you have a factory alarm system (not one that was added from a non-Toyota alarm manufacturer), the way to disable the alarm is to insert the key into the ignition, cycle the key from lock to on (not to the start position) five times. Try that and see if that fixes your problem. Remember, this trick will not work if you do not have a Toyota system installed.
Jul 30, 2011 | 1994 Toyota Camry
Car alarm was not set opened door and car was disabled now wont start
what wont start the car alarm or the car? if its the car you need to shut the door. unplug your key turn the alarm back and if you havfe remote start turn it on then shut off remote start and disable the alarm should reboot the alarm system. if not unplug the battery for about a minute it will reset the alarms disable car start feature
Mar 16, 2011 | Scytek 5000RS-2W Plus Full featured auto...
Car would not start. Put a new battery in and car started. Then locked car and set the alarm. Came out a couple hours later car would not start. Could it be the keyless alarm system its been acting funny...
Yes this is a normal problem with after market alarm systems. The system will lock out the starter or ignition system. have the alarm bypassed or removed.
Mar 23, 2010 | 1999 Ford Escort
2000 Chevy Impala, alarm remote issues
you should be able to however im not sure if it is associated with the on board system if all else fails reconnect it and maby change the batteries in the remote for a starting point
Sep 09, 2009 | 2000 Chevrolet Silverado
Need new keychain alarm button
Is this a factory installed alarm system? If so, unlocking the driver door with the key will allow the car to start. If not then you will have to remove the aftermarket alarm system to start the car.
If you have a factory alarm system you can get a new FOB (key chain alarm button) from a ford dealer, but it must be programmed using a scanner , before it will work in your vehicle.
May 23, 2009 | 1996 Ford Explorer
2005 Grand Prix remote start causes alarm to sound.
remote start systems have a dis-arm alarm output wire ... this must be connected to the OEM alarm disarm wire ... your installer needs to service it.
May 08, 2009 | OEM Systems Vehicle Parts & Accessories
1995 Volkswagn Jetta door lock fell off and alarm went off, car w
the same thing happened to my 1996 jetta trek.
when the alarm went off on me and the car would not start i walked around to the passenger door, locked and unlocked it, therefore the alarm went off.
but the alarm only went off if the car battery was low and had trouble starting.
Jan 15, 2009 | 1996 Volkswagen Jetta
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
Prestige Remote Start Logo
24 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
