Hoover vhd sensor dry
Left damp sock in drum can't find instructions what I use for a service wash please Ty
SOURCE: Baby clothes under the ringer
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: drying problems with hotpoint wdl 540p washer dryer
As it is a new washer, your best course of action is to the Hotpoint web site.
www.hotpopint.co.uk
then click on : after sales, for product advice.
Please leave a rating for my suggested solution.
Thanks.
Posted on Feb 17, 2009
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
SOURCE: I have a Hoover vhd sensor Dry Washer Dryer and
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Posted on Oct 03, 2010
Jahn27
  • 1554 Answers
SOURCE: Hi - Have a Hoover
The problem is with the water temperature sensor located at the rear bottom of the tub just above the heater. Remove the rear panel to access the sensor then check the wire harness connection. Make sure the wires are connected properly. Replace the sensor if no issue is found with the connection which is part number 49015420.
Posted on Jul 12, 2011
I have a Hoover VHD Sensor Dry 1400 AAA that trips the house fuse each time I turn it on. What should I do?
disconnect from the power outlet and call an technician to find the short or earth leakage problem
Feb 20, 2018 | Hoover Washing Machines
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Why my hoover is not drying very well its an automatic machine
Make sure the drain line isn't clogged with a sock or something small. Some models have a lint trap, usually at the front, that requires periodic cleaning. If the trap or drain line is partially obstructed, a first load's rinse water won't drain completely in the lowest part of the vertical drum you can't see. If this doesn't solve your issue, there is a pump problem.
Apr 09, 2015 | Hoover AAA160 Front Load Washer
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
My Hoover vhd 8142 washer wont turn. Some clothes got stuck in the doorway and when it spun it twisted everything up and pulled the seal off the door. We managed to get the seal back on. We put a load in...
Sounds Like the friction on the belt.If the drum got stuck the motor & belt keep turning plus the drum may of been pulled to an off set angle distorting the alinement's of the belt to the wheel that turns the drum.
Oct 01, 2017 | Hoover Washing Machines
I have HOOVER vhd 8143db80 when it went into its final spin, it started screaming. So I've taken the back off,I've noticed a lot of black carbon/metal dust on the pulley wheel. I've turned the...
That could be two things. Belts scream when they slip and are worn out. An bearings scream when they are dry or worn.
Your machine seems a bit obscure, as Google doesn't seem to know that model?
HOOVER vhd 8143db80 Google Search
VHD812
https://service.hoover.co.uk/manuals/VHD812.pdf
Feb 19, 2018 | Hoover Washing Machines
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Jun 23, 2010 | Washing Machines
Open Questions:
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
