Question about Hoover Platinum Lightweight Upright Vacuum w/ Canister, Bagged, UH30010COM
Hoover uh30010 wont stay running
Powers up motor then keeps shutting down
Overheated motor will not reset
It may take a while to cool and reset. If ity has been over an hour the thermal switch could be faulty.
Hoover WindTunnel WindTunnel vacuum cleaner Owner Manual Thermal Protector
Jul 13, 2016 | Hoover Vacuum Cleaner - Wind Tunnel
My henry hoover wont work
check main cable & power switch, mAY BE FAULTY
Feb 12, 2015 | Hoover Numatic Nacecare Henry HVR200A...
Hoover electrical diagram
Hi David. We recommend you take your cleaner to a Hoover authorized service center to have the motor on your C1810010 repaired or replaced. Follow the link below to find a service center nearest you. Thanks!
Service Center Locator
Aug 01, 2014 | Hoover Commerical C1810-010 Conquest...
Why won't my Hoover Platinum turn on?
Check and see if there is a reset button for the vacuum head this trips sometime to protect the head motor. Also if the roller heads bind they can snap the belt if it is belt driven. If it is direct drive then I would look for the trip or reset button.
May 14, 2014 | Hoover Platinum Lightweight Upright Vacuum...
Heat pure 1500 shuts down and displays 90.
over heating its self, it could be a blocked and not getting the right air flow or the sensor for the heat control is on its way out. check the filter if this model has one remove all dust from the intake, check that the fan is working, if the motor has been making any buzzing or funny sounds this can be the problem too. buzzing is the starter motor humming or clicking the motor is failing.
Mar 23, 2014 | Advanced Tech Infrared Heat Pure 1500 -...
Abs light on on the dash and a motor under van stays on when key is off
the motor you are hearing could be the abs pump. abs light will not come up on a code reader for engine as its classed as body part. if it is this pump then the system is faulty and the pump running can mean that it has a broken fin inside you cannot fix this part and another abs pump will be need to fix this.
Mar 11, 2014 | EBC Brakes 2001 GMC Safari - AWD, without...
Emptied the hoover and now it wont switch on
The switch that is activated by the canister is your likely culprit based that it was working prior to emptying. Youtube has a quick video on this solution.
Jan 13, 2014 | Hoover Turbo Power Long Reach Pets Utp1605...
Uh70600
Take the filters out and turn the vacuum on, if it will stay running without the filters in it you need to replace the filters. Filters should be replaced every few months. Clogged filters still pick up some dirt but miss a lot plus it causes the motor to run hot which will cause damage to the motor reducing it's life.
Nov 20, 2013 | Hoover UH70600 WindTunnel MAX Bagless...
We have model 11502 air purifier. Recently turned it on and it ran for a few minutes and then stopped. Motor sounded fine- no squealing, didn't slow down before it went off- just stopped like it was...
Yes there is a thermal cutoff that will shut the motor off for a period of time to protect it from getting to hot. If this is what happened after 20-30 mins. the motor should come back on and run again. If it does I would try to clean motor as best I could using a soft brush, vacumn, and blow out with air if possible. Clean fan of f as best you can to help motor run cooler.Hope this helps.Thank you
Jan 05, 2011 | Honeywell Air Purifiers
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
Hoover Platinum Lightweight Upright Vacuum w/ Canister, Bagged, UH30010COM Logo
Top Hoover Air Purifiers Experts
Thatvacguy.com
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
