Question about Hotpoint HSS25GFP Side by Side Refrigerator
Refrigerator not cooling on my GE Hotpoint HSS25GFTC
Cleaned all the areas and refrigerator still not cooling. No air coming thru the ducts I to refrigerator
SOURCE: refrigerator not cooling
Check in the freezer section by removing the food exposing the rear inside panel. DO you see frost beginning to build upon the rear inside panel of your freezer section? If so, the is a simple defrost problem and can be repaired easily. For testing purpose, st both control to the middle setting and do not move them during the entire testing period. Moving the controls only makes things worse.... Let me know what you find....
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
Posted on May 04, 2009
relaga58
  • 158 Answers
SOURCE: no cooling in refrigerator
air passage from freezer to the lower door maybe blocked with ice build-up
Posted on May 06, 2009
pride applia
  • 232 Answers
SOURCE: Refrigerator warm, freezer is fine.
this could also be a plugged defrost drain ice building up blocking air flow through the return vents is therehwater dripping into frige
Posted on Jul 01, 2009
heatman101
  • 43501 Answers
SOURCE: Hotpoint G/E Side by side refrigerator Model
There is ice build up hitting the fan....
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 25, 2010
Hotpoint refrigerator side by side
All of the cold air for the refrigerator comes from the freezer. Is there any ice build up behind the shelves in your freezer?
Feb 28, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a TBX25PBR 24.6 cu ft refrigerator.\r\nThe fresh food area only cools to 52 degrees even with setting at 9. The freezer operates normal set at C. The coils are very clean. Condenser fan is working....
Sounds like low Freon. Suggest have tech evacuate and recharge the Freon.
Also, most of them have a cold air duct from the freezer to the fridge area. Check to see that nothing is blocking that duct.
Mar 02, 2018 | GE Refrigerators
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
GE Hotpoint Top-Freezer model - freezer works but the rest of the refrigerator is not cold - even when we turn the cold dial up to 9. Model - CTX14C1TGLWH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 01, 2010 | GE Hotpoint Top-Freezer Refrigerator
HSS25GFTABB water not coming out dispenser. Have thawed water line serveral times why does this keep happening
This is a defect in refrigerators made by GE. They have replaced some doors because of this. You might want to try your luck and call GE.
Some people have taped insulation to the inside of the door in the area below the dispenser with duct tape,.
. GE makes a heater that will prevent this from happing again. The part number for this heater is WR49X10173.
Feb 14, 2010 | Hotpoint HSS25GFP Side by Side...
On my refrigerator hotpoint model hts22gbmarcc is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 30, 2009 | GE Hotpoint Top-Freezer Refrigerator
My freezer works fine, but fridge doesn't cool down below 55 degrees. Could it be the adjustment dial in the fridge.(i have cleaned the dust and dirt out of the back/bottom.
It sounds like the circulating fan is wearing out. The fan circulates air thru the freezer as well as the refrigerator. When it starts to wear out the force is reduce to a point that the freezer will get cold but the refrigerator will not get cool.The minimum cost of the assemble is around $300.00
Jul 10, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Jun 22, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
heatman101
May 06, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Hotpoint HSS25GFP Side by Side Refrigerator Logo
43 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
