Question about Toshiba CT-90326 Remote Control
User manual my father has accidently changed channel that his sky was on and I need to know how to get it back to the correct channel so that he can see the sky signal. the sky box is switched on but comes up on screen no signal recd.
2 Suggested Answers
  • 70 Answers
SOURCE: hi i just bought a new tv connected up my sky box to it, and when i try tune it just comes up no signal please re tune in it
check connections
Posted on Jun 07, 2012
US Army 3.5 Channel Sky Runner Gyro RC Helicopter. Where can I download an owner's manual?
Excalibur Sky Runner User Manual
Try to read the pdf of the user manual of Sky runner.I hope it can help you to solve your problem. thanks
Apr 10, 2016 | RC Toys
I accidently changed my tv channel i have dish how do i get my dish back
Meshell Coles,
I would be happy to help get this fixed! If the TV is connected via a Coax cable, try changing it to 3 or 4 if TV1. If it is TV2 try 60 or 73. If the receiver is connected via a RCA (Red, Yellow, White) cable, HDMI cable, or Component (YPbPr), make sure the receiver is on the correct input.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
Sep 02, 2012 | DISH Network Televison & Video
I have acquired a Panasonic NV-FJ620B-S Video Cassette Recorder which has 2 x scart sockets on the back. 1 marked AV2 DECODER/DECODEUR(EX) the other AV1 (TV). The AV1 scart connector works fine on the TV...
Have just visited the Panasonic UK website and the User Manual for the Panasonic NV-FJ620B-S is available free. It lists on page 11 all the details. I'll e-mail it you Tom to see if it helps.
Jan 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Users Manual on how to use
Motorola Walkie Talkie Code and Channel Setting
  1. Push and hold On/Off button. It will tell you Code & Channel
Note: You are now in the change mode
  1. Change Code - Push the talk button till handsets match Code then push monitor button to accept
Note: You are still in the change mode so you can change Channel
  1. Change Channel - Push the talk button till handsets match channel then push monitor button to accept
  2. To check repeat step 1 then push on/off button
Dec 19, 2008 | Motorola Walkie Talkie 2-Way Radio
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Toshiba CT-90326 Remote Control Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
