Question about ASUS P5N32-SLI Premium Motherboard
Extreme slow performance, cpu performance maxed out
Installed with intel core2 duo 2.4, 4gb ddr2 667, hitachi 400gb sata 16mb cache, winxp home sp2 hoffixes and updates all present.
3 months old.
pc slow response to most things esp. internet programs, has tendancies to freeze, crash and or turn self off indicating "windows recovered from serious error"
Have taken in to repair shop - installed new OS + checked speed - state nothing wrong
helppppppppppppp am at wits end
have tried all configs of memmory from 1gb, 2gb 3gb etc
bios date is october 2006
  • The Spook Oct 29, 2007
    thanks guys, seems a bit harsh though that the ebay shop sold me the bundle of board chip and mem together - any suggestions then apart from either buying an inferior chip or a new mboard - mother board spec states core 2 duo but doesn't stipulate fsb compliance
    is ther any way i can test the board and or chip without going to  a tech shop for them to charge me the earth?
  • 4 Answers
Asus P5N32 SLI Premium according to Asus Website doesn't support any core 2 duo cpu except for 2000 series which is 800 FSB.  So if you have a 2.4GHz, you may NOT be running at the proper speed.
Posted on Oct 29, 2007
  • Solomon Lee Oct 30, 2007
    Well, you really don't need to buy anything else, even though technically the board doesn't support 1066 FSB, I believe you can go into bios and change the frequency to Manual , then set to 1066 (if your cpu is a 1066 FSB one which probably is).  Its the same procedure as overclocking except in reality, you are just using the overclocking feature of the motherboard to run the cpu at its' intended speed.  If you are not comfortable doing this, maybe see if you can get someone to help you or you can contact me directly for help.
  • 196 Answers
Boot to safe mode and see if the problem is the same.
Have you checked for viruses and spyware?
Look in Control Panel/Admin Tools/Event Viewer, System and Application for red marks.
Do you have a temp monitor installed?
Have you changed anything in the BIOS? Set to safe defaults.
Posted on Oct 27, 2007
  • Hugh Vandervoort
    Hugh Vandervoort Oct 30, 2007
    Have you done any of the basic troubleshooting I suggested?
    Have you checked with ASUS tech support? They are very responsive, in my experience, and the forums are good also.
    It's odd to rate a response as "Not helpful" without trying any of the offered advice.
SOURCE:
Intel core tm duo cpu e4500 motherboard
Intel = Processor (CPU ) manufacturer
Intel Core tm = Trademark. The Intel Core is a Trademark from Intel
CPU stands for Central Processing Unit. Another term used is Microprocessor, or simply - Processor for short.
e4500 is an Intel Core2 Duo processor.
Maximum frequency rate ('Speed') is 2.2GigaHertz.
2MegaByte of L2 Cache. (2MB of L2 Cache)
800MegaHertz Front Side Bus. (800MHz FSB)
Tells me Nothing about the actual motherboard. Look on the motherboard for a Model Number. May be in center of motherboard. May be on edge of motherboard. May be in-between one of the expansion slots, on motherboard.
Post back in a Comment.
Also post what the problem is, in your best description.
Computer does not turn on. (Power Supply does not turn on)
Computer seems to turn on, but get No Signal on monitor, or Sleep Mode on monitor, or Power Saver Mode on monitor.
LED lights light up, and fans spin.
Regards,
joecoolvette
Apr 23, 2013 | Computers & Internet
What is the main difference between a dual core CPU, and a Core2 Duo CPU ?
A dual core processor has two cores (essentially, two CPUs on one chip). Core2Duo is a specific dual-core processor design. Thus, all Core2Duo CPUs are dual-core CPUs, but not all Intel dual-core CPUs are Core2Duo designs.
Essentially all current Intel consumer dual-core CPUs today are Core2Duo designs. They have different names, but vary mostly in terms of their FSB speed (mostly, how quickly data can be transferred to/from RAM) and in the amount of cache memory in the CPU (cache memory is a relatively small amount of high-speed memory on the CPU chip that stores frequently-used data and instructions; it can improve performance 4-15% or so, depending on the amount).Best Regards, Luis.
Mar 02, 2012 | Computers & Internet
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
2 Sata HDD not working at a time
In the bios be sure that all the parameters for the SATA drives/devices are AUTO
Dec 11, 2008 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
Cpu enquiry
There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
I hope this answered your question.
Greetings,
DarkNeogen.
Jan 25, 2008 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
D345AJ
Not sure what information you were requesting. So here is some information about your motherboard:
- LGA775 socket for Intel® Core2 Duo/65nm Pentium D/Pentium 4/Celeron CPU
- Intel 865G + Intel ICH5
- 1066(O.C)/800/533 MHz
- Dual-channel DDR400
- Intel® Extreme Graphics 2
- 1 x AGP 8X
- 2 *ATA133 ,2 x SATA
- 10/100/1000 LAN
- 6-Channel audio
Here is a link to all the drivers to your motherboard:
This includes the manual!
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
If you need more help Let me know. :]
Dec 10, 2007 | ASUS P5PE-VM Motherboard
ASUS P5N32-SLI Premium Motherboard Logo
78 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
