Ativa lcd monitor
When I turned on the computer the monitor light is yellow, which I assume means caution, and nothing appears on the screen. Then I cannot turn off the computer without turning off the power. When I hit the monitor switch it turns green for a short time and then indicates "no signal" and goes black. The mouse does not work at all ... but I still cannot turn off the computer without turning off the power completely. What is the problem?
  • Computers & ... Master
  • 3,261 Answers
I think there is a problem with the power on the pc. if you can unplug the lead to the monitor and it works fine. but on the pc will not work, mouse can be connected. the graphics card could be the fault, it could be shorting out and making the power fail. this can damage the psu at the same time if not sorted.
Posted on Jun 29, 2017
computafixa
  • 317 Answers
SOURCE: Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Posted on Feb 21, 2008
SOURCE: Monitor screen goes out (black) 2 seconds after turning on
Your site is extremely misleading and fraudulent. I was under the impression that I would at least get a hint at what might be a problem instead of you folks making me wait to get a money for something answer that you could have displayed on your main page. Places like yours have no place on the internet and I'm going to find out what I can do to report you.
Thank's for nothing
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Posted on Feb 14, 2009
byteguy
  • 2229 Answers
SOURCE: Power light is green but screen is black
Do you get anything at all on the screen--like white writing at startup?
Even if your video drivers have become corrupt, they are not used until Windows actually starts.
It very well could be the flourescent backlight has gone bad. Can you adjust the brightness/contrast at all to see anything?
If those controls do nothing for you, then you're looking to get a new monitor.
Your monitor does have a sort of power supply for the backlight and that could be bad, but if you're not into taking it apart, then you are far better off buying a new monitor.
Posted on May 27, 2009
  • 286 Answers
SOURCE: My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Posted on Sep 15, 2009
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Lcd monitor working fine but the adjustment screen apears on my monitor in a small square enveloppe how can i restore system thanks in advanceDewulf Jan
I assume by "adjustment screen" you mean the OSD (On Screen Display). This is the box where the menus for adjusting the screen appear. If I'm correct, that means you have pushed the "menu" button on your LCD and need to push it again to turn the OSD off. If pushing it again does not solve the problem I would say it's time to have the LCD repaired. In many, but not all, that OSD goes off on it's own after a bit.
Mar 01, 2014 | Relisys TL565 15" LCD Monitor
Black display
You say black display. Not sure what you mean. Either the monitor is working or it is not. If you see nothing on the monitor and the power light is yellow, then it is not getting a signal.
If the power light is green and you see nothing, look really closely. You might even shine a flashlight at the monitor to see if there is actually a dim display. If so, the backlight has gone out and needs to be replaced.
I'm assuming that you have tried to brighten the display with the monitor controls.
Jan 09, 2012 | ViewSonic VA720 17" LCD Flat Panel Monitor
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
LG LCD monitor goes in power saving mode
That means theres no signal coming from the PC. either the PC is not booting up or the VGA coard is faulty.
Nov 25, 2008 | LG L1915S 19" LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor w2gen mg15vt
I had a somewhat similar problem. Mine was still under warranty. bad news is that x2gens parent company just filed for chapter 11. which is why their RMA website is unresponsive. I bought mine through a 3rd party retailer who refunded the entire purchase price of the monitor. HELL YEAH! Good luck unloading all ur x2gen stuff when it craps out cuz all warranties are essentially useless now.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
