Question about Olympus Vn702pc 2gb Digital Voice Recorder V405171su000
Remote busy When my recorder is plugged into the computer it states the remote is busy...which it isn't
Finalize
You have somehow configured the remote to control another DVD recorder, this is useful if you have multiple recorders you want to control with a seperate remote for each one.
To set it back to Remote DVD 1, hold the enter button in the centre of the remote along with the number 1 for 5 seconds.
Hopefully now it will control your recorder properly.
Oct 24, 2007 | Panasonic DMR-E55 DVD Recorder
My Canon XL1 pause /record button isn't working how do I fix it?.
I called B and H and the person that answered the phone suggested I attach a remote. The record, zoom and all other buttons are on the remote. It only costed 29 dollars and now my record button on the remote works. Hope that helps someone.
Jun 18, 2012 | Canon ZR50MC Mini DV Digital Camcorder
Thomson freeview dv3 recorder
Buy one universal remote control, which have setup codes for your Thomsun device. Brand name isn't matter.
May 06, 2012 | Thomson Internal Push Ring,id 2.000 In -...
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
Sep 24, 2011 | Panasonic DMR-E55 DVD Recorder
Umm my tv2 remote isn't connecting to my reciever so i tried to change the remote address and it doesn't work
Hi my nameis Mike Houston of DISH Network and I see your TV2 remote isn't connecting toyour receiver. You will want to make sure you're at the TV1 location to programthe remote for TV2, press the Menu button 2 times and you will see the SystemInfo screen. On the bottom for the screen you will see the remote address forTV2, make sure the TV2 remote has fresh batteries inside. On the back of thereceiver their will be a Remote Antenna port and you want to make sure that ishand tight. Push and release the SAT button and press record and you should seethe address change for TV2. I will send a link to help with these steps; http://www.dishnetwork.com/SupportSection/remote-control.
Jul 30, 2011 | DISH Network 322 DTV Receiver
The screen on the remote is working however it doesn't seen to be make a connection to the unit therefore the aircon unit isn't turning on. How can we fix this?
This sounds strange but if you have a mobile phone with video recording on it, run the video whilst pressing the remote control. If you point the camera at the end of the remote (Where the glasslike bubble is), you should see it flash ( On the camera) You will not see anything with the naked eye, you must look at it through the camera while on video record. If you see a flashing, it means the remote is OK and you will need what is called " a receiver board" in the indoor unit of your aircon. If it doesnt flash, it means the remote is faulty. Try the manufacturer for a replacement .
Bye the way, any remote control can be tested in this way... try it with your TV remote to confirm it works..
Jun 16, 2011 | Heating & Cooling
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Olympus Vn702pc 2gb Digital Voice Recorder V405171su000 Logo
24 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
