Question about Ricoh Aficio SP 5210SF Multifunction Printer
Change paper thickness setting - Ricoh Aficio SP 5210SF Multifunction Printer
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
I was printing on a A4 thick (invitacion Card)
Make sure there is 1/16 to 1/32 inch space on each side of the paper in the paper tray.
Move the paper type selector back and forth 5 times, to make sure it is not stuck.
Feed the tray with a minimum of 20 sheets of paper and try to see if it loads paper through.
The paper thickness lever has two settings, one for plain paper, (thin paper 20# to 24#) and one for envelopes and thick paper.
It should be on the 0 setting for thin paper and on the + setting for thick paper and envelopes.
The paper adjustment lever may be adjusted in between the two settings to accommodate paper that is not standard or that the operating/environmental conditions have changed.
Make sure the paper is loaded far enough into the printer to ensure good contact between the paper and the paper feed mechanism.
Dec 05, 2009 | Epson Stylus Color 600 with GT-5500...
Thick paper won't print
check ur printer settings and try again if not soloves to and change the paper better to use thick paper
May 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Printing on thick paper
The driver for this printer has a setting for thick paper. It is toward the end of the list of paper types in the HP supplied print driver. When "Thick photo paper" is selected, the printer releases some of the tension on the pinch rollers as the paper is being fed in. Otherwise, the paper is too thick and the last set of rubber rollers will not grasp it. Unfortunately, this feature is not included in the updated driver for Win XP. It only exists in the original Win 95/98 driver. It is not even in the HP supplied Open Source driver for Linux, either. I still maintain a dual-boot machine with Win98 SE because of this very problem.
Jan 06, 2009 | HP DeskJet 1220c/ps InkJet Printer
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Canon i560 colour printing problem
have you tried changing the cartridge..?
Jul 29, 2008 | Canon Office Equipment & Supplies
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Printer
Before I go into your solution I have to mention a few things first. Your printer software utility has multifunction printing capabilities. What I mean is you can print on thin paper , thick paper , and even glossy paper. I would go into your settings for your printer specifically for pictures or graphics and see what the paper thickness size is set for. Compair this to your setting for normal text printing and change your picture and graphics settings so it matches your text printing. I would also check on your printer some have a flip switch to set the printing head height. If it is selected low this could also cause scratching.
Aug 20, 2007 | Brother MFC-3240C All-In-One InkJet...
Ricoh Aficio SP 5210SF Multifunction Printer Logo
10 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
