Question about KitchenAid KUWA244PBS Wine Cooler
Need dimensions and new model that would fit - KitchenAid KUWA244PBS Wine Cooler
Midea WQP12-9240AS
Just get out your measuring stick and measure the space you have - go to store with dimensions and you will get a unit that fits.
Apr 02, 2016 | Dishwashers
I need the dimensions of Amana side by side fridge freezer. Model no. sBDE520SW
U contact the manufacturer of the remote for the codes, if any.
Mar 07, 2016 | Amana Refrigerators
How do I get the dimensions for a fridge freezer?
Looks like they are the same outer dimensions.
Old:
New:
  • Width of cavity: 560 mm
  • Height of cavity: 1772-1776 mm
  • Depth of cavity: 550 mm
http://www.appliancesdirect.co.uk/p/ckbc3150euk/candy-ckbc3150euk-integrated-fridge-freezer#maindesc
Oct 06, 2014 | Refrigerators
I have a pulsar 150 2011 model i want to replace the bulb with HID xenon angel lamp. i want to know the dimensions which would fit
You dont need dimensions just H4 or H7 or whatever is marked on bulb, they will all be same size
Ride Safe
Bike-Doc
Jan 07, 2012 | Bajaj Pulsar 150 Motorcycles
I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
I have this exact model. Here are the specs:
depth: 30"
height: 68.5". with hinge: 69.5"
width: 35.5"
15.5 cubic feet in the refrigerator section
10.0 cubic feet in the freezer section
25.5 cu ft total
Sep 08, 2011 | Kenmore Refrigerators
Need new battery for Nextar gps yoku battery 3.7v
eBay... 3.7v generic lithium polymer battery. Check dimensions to make sure it will fit inside your device (most sellers have a pic with the dimensions of the battery). Solder red to red and black to black.... Reassemble device, and your done.
May 29, 2010 | Nextar Q3 GPS Receiver
I need the dimensions for GE dishwasher GSD500G. For fitting a replacement washer.
Under the counter dish washers are very standardized. Just measure the current counter height and width of the opening. Nearly everything will fit unless it's a special order. GSD500G install dimensions are available on-line. Just Google the Model Number.
Aug 02, 2009 | Dishwashers
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KUWA244PBS Wine Cooler Logo
11 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
