Question about Shinwoo SB-1000 Mixed Money Counter
Image m not working - Shinwoo SB-1000 Mixed Money Counter
After capturing the image it will show like a mirror image
"the image show like a mirror image"? What image? In what? Why are you entering F2? I'm not clear what the problems are?
Dec 30, 2012 | Dell Inspiron 15R 5520 Core i5-3210M...
N73 nokia, i have problem in take of the image capturing , in the image capturing mode doesn't key accept for image capture but it has work for video capturing. so plz help me what i do?
Generally the image capturing button should press 1-3 secs to get a picture.If it doesn't works there might be some hardware problem.But first try to Restore the phone by typing *#7780# and capture.If the problem still persist contact mobile repairing shop. The camera switch may damage .Or at least clean the pcb if you can remove the cover ..Thanks for visiting fixya
Mar 18, 2012 | Nokia N73 Cellular Phone
Cam come on on yahoo but not michrophone
Hi there
I can understand issue.. Please check this image and follow it up..
Method 1:
Click start lower left on your desktop.
Click control panel then double click sounds and audio devices.
Click audio tab ensure your speakers and mic are the default devices do the same with the voice tab.
If not change them and click o.k.
You can also check your equipment while you are there.
Also click actions top line of the messenger window, scroll down and run voice setup.
This should work for you. If not then try the another method.
Method 2:
Please follow the instructions as per below image.
Image 2:
Image 3:
Image 4:
Image 5:
Image 6:
Image 7:
Try this and i hope it will work.. All the very best..
Jan 23, 2010 | Logitech QuickCam Pro 5000 Webcam
Can't change my ym display image
Did you delete it from yahoo profile in program file? But that is not suppose to happen. Well click on displey image option on yahoo messy...click on browse and when the window for image will be appearing with list of image delete all the image (Delete Picture) showing there ....now click on browse and go to that folder where you kept the image you want to add as your displey image....and proceed...I think it will work fine....If that is also not works....check that you shared your displey image....Good Luck
Oct 16, 2009 | Yahoo Messenger
THe scanner works but the image is blank/no image
Try automatic settings or vary the brightness/contrast setting and scan. This should work. S. Mohan
Jun 13, 2009 | HP Scanjet 4470c Flatbed Scanner
My display picture will not change in messenger box
Go to folder
C:\Program Files\Yahoo!\Messenger\Profiles\[your Yahoo ID]\My Icons
It's a list of display images saved by YM. Remember the filename of your desired image.
Open your registry (click Start, Run.., type REGEDIT).
Trace the path
HKEY_CURRENT_USER/Software/Yahoo/pager/profiles/[your Yahoo ID]/FriendIcons
The value of Path should reflect the filename of the current display image in your YM. Change it to reflect the filename of your desired image.
Close the registry.
Restart YM.
User is online!Profile CardPMEmail Poster
Go to the top of the page
Dec 06, 2008 | Yahoo Messenger
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Printing a mirror image
I called a Canon rep and the printer does not have that option on it.
Feb 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
RoboHelp HTML -- cannot check out image
By "check out" image, what do you mean? If you mean it does not display, filenames are case sensitive, so make sure the HTML code correctly calls the .gif file with the right case.
Aug 09, 2007 | Macromedia RoboHelp Office X5
Shinwoo SB-1000 Mixed Money Counter Logo
106 people viewed this question
Top Shinwoo Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Shinwoo Retail Supply Expert? Answer questions, earn points and help others
