Question about Janome Memory Craft 4900QC Mechanical Sewing Machine
Increase size monogram 4900qc
Enlarge monogram
Can one increase the size of the "preloaded" patterns on this machine?
Perhaps if you read your manual it will tell you I see no mention of a make to get a clue.
May 23, 2016 | Sewing Machines
How do I enlarge a monogram stitch?
Depends on your sewing machine. If it is an embroidery machine, you can most likely enlarge it via software. However, if you have a computer with built-in alphabet, you are most likely limited to the size of the presser foot, needleplate, etc.
Dec 21, 2015 | Sewing Machines
How do i enlarge the font size for embroidery
If this is the built in font on the sewing machine, they are pretty standard size. To make large fonts usually takes an embroidery machine and pre-digitized fonts or software with fonts or the ability to create fonts in the sizes you are looking for.
You can with practice learn to create your own lettering using a satin or very small zig zag stitch which is the original way monograms were created.
Jan 04, 2015 | Sewing Machines
How can I get the monogram to work properly?
On my sewing machine that would be an indicator of misadjusted thread tension. Changing thread type or diameter generally requires tension adjustment. In this particular case, I\'d increase the bobbin tension a bit (if I understand your description correctly, the bobbin thread forms loose hoops), and back off on the upper (spool) tension (pulls too hard on the thread). On one or two of my bobbin cases, I had problems with the tensioner screw working loose during use. I put a dab of nail polish on the screw head to stick it to the bobbin case. Problem solved.
I\'m not familiar with your particular machine, but I don\'t see why you can\'t make the character any size above the minimum (which would be the smallest readable character that can be made with the stitch length and type used).
Apr 24, 2014 | Kenmore Elite Clothsetter 19010
How do I increase the size of applique letters on the Horizon 7700
Applique and Letters (MONOGRAMMING) are two different things
Check pages 67 & 80 of your manual
Letter size is fixed, not variable
Apr 03, 2014 | Janome Sewing Machines
Thread gets stuck after second stitch
Let me guess,.... When you start to sew you do not grasp the loose thread ends. Grab them babies and hold on for about an inch or more of sewing.
Sep 23, 2013 | Janome Memory Craft 4900QC Mechanical...
Can you attach a computer (laptop) to a janome memory craft 4900qc
Any sew and vac store that services Janome would be able to order that for you.
Sep 25, 2012 | Janome Memory Craft 4900QC Mechanical...
Monogram larger
the two sizes of monograms letters are upper and lower case
Feb 21, 2008 | Kenmore 19606 Computerized Sewing Machine
Janome Memory Craft 4900QC Mechanical Sewing Machine Logo
44 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
