Question about HP Slate 7 4600 16GB Tablet
Tablet icon not responding. Touchscreen is not repsonding
How can I improve the touch of my screen it takes forever to respond
Hi it's possible youre tablet has a faulty glass screen digitizer ,cheers
Sep 06, 2016 | Tablets & eReaders
Why doesn't my 7inch Tagital tablet respond to touch?
Do you have a feature in your settings menu called Calibrate?
Often times tablets and other touchscreen devices have this option and needs to be re-calibrated. Hope this helps you out.
Jan 17, 2016 | Tagital Tablets & eReaders
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
Broke my screen, still turns on and shows picture but touchscreen no longer responds. Is there a repair for this type of discrepancy?
Screen repair is a common fix. Check the yellow pages for a repair person or service. Depending on the damage the repair may not be worth the phone.
Feb 09, 2015 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
How do I get my trio to go back to the home screen?
It could be that your touchscreen (digitizer) is PARTLY broken.
To confirm, try rotating your tablet 180 degrees, and then touch the home button again.
If it works when rotated then you need a new touchscreen.
I hope you are good with precision tools, and have good mechanical skills and instincts: it's a rather intricate job to locate the locking tabs and screws that attach the touchscreen to the insides of the tablet, then remove them, and finally to replace a touchscreen. And then reattach all necessary fasteners, and test whether it will work properly.
EASIER FIX: go to Ebay and buy a used Trio tablet. it may cost you only $40 to $50 maybe even less!
Sep 27, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
Tablet touch screen won't respond
You may have a damaged wire connecting the screen to the phones mother board
Sep 05, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
When I try to start my Samsung tablet I get as far as the swipe screen to unlock but the touchscreen isn't responding. Any ideas?
Go to Samsung dot com and post this question there... I've looked and I haven't a clue at this time
Dec 27, 2013 | Samsung Galaxy Tab Tablet PC
Pen and touchscreen not responding on my Dell Latitude XT2 Tablet PC
Hmmm does the penn have a battery then? I guess something is wrong with the wiring as not just the pen does not work but touching all all not. Stuff should just simply work and not require loads of troubleshooting.
Oct 06, 2010 | Dell Latitude XT2 Tablet PC
Fujitsu p1120 touchscreen not working
Before you open up your computer, try downloading the touchscreen drivers from Fujitsu's website and re-installing them. Sometimes they just get flaky.
Mar 19, 2008 | Fujitsu LifeBook P1120 Tablet PC
HP Slate 7 4600 16GB Tablet Logo
11 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
Lawrence Oravetz
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
