Question about Wahl Health & Beauty
Battery will not hold charge
Wahl 5000 shaver shaper battery will not hold charge
  • 193 Answers
Give Wahl Uk a call
Posted on Feb 11, 2014
4 Suggested Answers
Cytherian
  • 109 Answers
SOURCE: My shaver won't hold a charge.
Yes, you can replace just the batteries. It's fairly common that the motor will last far longer than the batteries, so you can purchase them separately and install them. You can usually find them at about $12 a piece on "that auction site." Here are the instructions:
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Posted on May 23, 2009
Cytherian
  • 109 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Posted on Oct 22, 2009
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
brector3
  • 1610 Answers
SOURCE: Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Posted on Jan 16, 2010
I own a Wahl 5 Star Shaver and plugged in a non Wahl Charger cord into the device, heard a spark, and then unplugged it. I found the original Wahl charger cable, but the device won't charge; even after...
I'm afraid you blew up your shaver. Only if they build in any over voltage protection or a fuse it could be the damage is limited, but I think a engineer should look into the shaver, or perhaps you better buy a new one?
Jan 18, 2015 | Wahl 5 Star Shaver WA8061
Not charging
I would get it replaced.
Mar 10, 2014 | Wahl Health & Beauty
Battery will not hold charge on my wahl lithium ion trimmer. Model 9854L. Do I need to replace battery? If so, how do I do that? Have trimmer for about 3 years
The battery may only be supplied with the charging circuit attached, best check with your local Wahl service agent. Lithium batteries are not generally sold to the public as they are dangerous (explosive) if charged incorrectly.
Oct 11, 2013 | Wahl Health & Beauty
Change battery wahl 9918c
How to change the Battery in a beard trimmer - YouTube
? 3:38
https://www.youtube.com/watch?v=QlLqB9S5oaI
Oct 20, 2013 - Uploaded by Shake the Future
Do you have a beard trimmer/clippers that don't hold the charge? Time to change the battery and give your beard trimmer a second life. .... Wahl Trimmer All-In-One Lithium Ion Unboxing - TimmyTechTV - Duration: 6:32. by ...
Jul 28, 2012 | Wahl 9916-800 Groomsman Beard Trimmer
Where can I find the a replacement battery for my Wahl 9876 shaver
Unfortunately, those batteries are not replaceable. If you've had it less than five years, it may still be under warranty.
Mar 18, 2011 | Wahl 9876-500 Beard Trimmer
Need a new battery for my Wahl 5000. it won't hold a charge.
CONTACT THE COMPANY AND THEY WILL LEAD YOU TO WHERE YOU CAN GET A NEW BATTERY.
SHERRI
Feb 07, 2011 | Wahl Health & Beauty
The power seems to have dropped so the blades arent running on my shaver
how long have had this cordless trimmer, you may need to replace the rechargeable battery inside the trimmer. if so have Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Mar 29, 2010 | Wahl 9918-600 Beard Trimmer
Wahl 5000 mens shaver
I had the same problem. All the lights were lit but the shaver would not work even when plugged into an AC outlet. I took it to Mar-Beck Appliances in Independence MO and they said that it needed a new circuit board and the total cost of the repair would be $59.90.
Apr 01, 2008 | Wahl 5000 Custom Shave System Electric...
Health & Beauty Logo
323 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
