Question about Goodman GDS80904BNA Open Flame Heater
Gmp075 3 ignitor
Didn't ignite, replaced igniter, that one blew, as in like a fuse, over night it blew
    Novelist:
  • 189 Answers
Never touch the part of the ignitor that glows. oils from you hands can cause problems. make sure that the ignitor is not shorting out on anything. When it is glowing the red part not not be in contactac with anything.
Posted on Nov 28, 2014
3 Suggested Answers
  • 2515 Answers
SOURCE: Goodman GMS80903BNA ignitor goes out just as gas
check out the pressure switch........... i take it glows red gas valve clicks then goes off,
Posted on Dec 03, 2010
gargac
  • 39 Answers
SOURCE: Furnace ignitor comes on glows little red gas
Check your conection off the board to the initor and make sure the pins in the plug are set tight with the connection on the board. If you wire nutted the wiring together for the new ignitor you installed check these connection also. Make sure all wire strands at the wire nuts are in the wire nut and not touching or arching on the furances cabinate.
Posted on Feb 01, 2011
Igniter issue
unplug the cord to the heater element if still pops unplug ignitor if still pops bad board if ok plug in ignitor if pops bad ignitor if ok plug in heater if pops bad heater element or cut wire
Jul 10, 2014 | Dometic Refrigerators
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
2005 Saturn Vue Repetitive Ignition Fuse Failure
I think there is a short in the system, possibly happened while replacing the main brain.
Jun 19, 2012 | 2005 Saturn VUE
Fuse on main ing box
Are you sure you didn't have the jumpers backwards? Sounds like the best place to start investigating now is at the ignition switch. Something is crossed out in the circuit...
Best Regards,
Ck
Dec 03, 2011 | Yamaha V Star 1100 Classic Motorcycles
Dryer igniter does not ignite?i have replaced the igniter.
also check the sensor if ignitor isn't glowing,get a meter and read the parts out instead of just changing them out,check the sensor,ignitor and gas coils,on some models the thermal fuse could be bad,is there power going to ignitor?you can't tell until you read em out with a meter, and alot cheaper, hope this helps
Nov 11, 2009 | Kenmore 73952 Gas Dryer
2002 GMC wiring problem
get one from junk yard sounds like a dead short somewhere check around starter wires!!! :)
Jul 06, 2009 | 2002 GMC Yukon XL
Pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Feb 02, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
No Heat on a whirlpool dryer. 14 years old.drum turns,timer moves,getting gas to valve,tapped solenoids-no change.burner not lighting. thanks for any info
if ignitor not coming on could be flame sensor mounted on side of burner housing or ignitor ..if ignitor glowing but burner no lighting replace both solenoids bad connections interally on solenoids..also if ignitor not glowing possible small white thermal fuse open.. sensor and fuse can be jumped across to confirm ..
Dec 22, 2008 | Dryers
Heating & Cooling Logo
49 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
