Question about Canon PowerShot A630 Digital Camera
Video is grainy
Pictures are still very clear but when shooting video it is very distorted and grainy. Change SD cards, still the same.
I used an extreme 32gb memory card with my Nikon 80 and first time ever-got grainy-poor resolution pictures. How can I improve their quality
Try changing the ISO setting from AUTO to 100. Fast ISO speeds create more grainy photos. The SD chip should not have any affect on sharpness. Either you ISO is too fast, or your shutter speed is too slow. You might also try formatting the sd chip using the menu on the camera.
Jun 10, 2014 | Computers & Internet
Why low resolution?
Uploading them via the SD card will have no effect on the resolution.
There is a difference between image grain and image pixelation.
If the resolution is too low for the size you are printing the image will pixelated, meaning that it will be made up of lots of little squares.
If the image is grainy it may be that you are shooting images in low light at a high ISO setting on the camera. Typically with the lower end Canon cameras anything above 800ISO will start to look grainy.
Jun 19, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
I can not put memory card inside the camera, this card is ritzpix 2GB. Can u please tell me what can be the problem?thank you
Your problem is that you are not using a suitable memory card for the D90. 2Gb SD cards have read/write speeds that are much too slow to work with quality DSLR's. Let me explain. When you take a picture with the D90, the data generated first goes into a small capacity buffer memory. The purpose of the buffer is to act as a conduit to your SD memory card and retain picture data until all of the data is safely written to the SD card. If your SD card can accept data as quickly as the buffer can pass it to the SD card, there is no problem. But, If the SD card is not capable of accepting the data quickly enough, the buffer will start to fill up since data is coming in faster than it is going out. If you take pictures in quick succession with a slow SD card or if you shoot video with a slow SD card, the buffer will overflow; i.e., fill to its capacity and become incapable of accepting more data until its capacity returns as the SD card accepts the data. During that time, the camera will prevent you from taking any more still photographs. You will push the shutter release and nothing will happen. If you are shooting video, the camera will continue to work, but the sound will loose sync with the picture.
For your D90 to function properly under all conditions, you must have an SDHC card that is rated at 45Mbs or faster. When I first bought my D90 several years back, 35Mbs was the fastest card made and I had the problems I described to you above. When Sandisk brought out the Sandisk Pro card with a 45Mbs speed my problems melted away. I should also ad that 2Gb is much too low of a capacity for the D90. It will fill up very quickly if you shoot Raw or fine quality jpeg files. You need a minimum of 8Gb.
Sep 26, 2011 | Nikon D90 Digital Camera with 18-105mm...
When using my Nikon CP 5400 - the videos are not longer clear and are grainy - is this a card issue or the camera? Also the camera is slow in capturing the current shot I am taking and I now miss the...
This sounds like an issue due to low light. The card will not cause the video or pictures to be grainy, but high ISO settings (used to compensate for low light) will. In low light, auto-focus has a hard time and usually a camera won't take a shot unless focus lock occurs.
Assuming you were shooting in a low-light situation, the solution is to add more lighting to the scene.
Note that the flash on your camera is only good for a distance of about 10 feet.
Mar 01, 2011 | Nikon Coolpix 5400 Digital Camera
If the camera says the internal memory is full and won't allow me to take any more pictures, do I need to get a new card reader?
Your camera has only 32MB of internal memory, out of which only 13.5MB only is used for picture storage, which allows you to save only a few pictures. If you need to shoot more pictures you need to buy SD or SDHC cards or micro SD cards. If you buy micro SD card, then you also need to buy an SD adapter. SD adapte is very cheap, usually less than a dollar. The maximum size SD card you can use in Kodak Z915 is 32GB SDHC card. SD card sizes are available only upto 2GB. SDHC cards goes from 4GB to 32GB. Again these cards are rated based on their speed classes. It is preferable to buy Speed class 6 and above for good video recording. With higher speed class, speed increases. If you want to shoot pictures faster then you need higher speed class memory. Price of the card increases with the speed class. You can buy speed class 2, 4, 6, 8 or 10.
If you want to download your camera manual, try the following site:
http://resources.kodak.com/support/pdf/en/manuals/urg00995/Z915_xUG_GLB_en.pdf
Jan 14, 2011 | Kodak EasyShare Z915 Digital Camera
Cannot get channel 2 clearly
Normally grainy pictures are a result of poor ground connections, although usually for more than one channel. Check the cable connections first. Otherwise all I can suggest is to have the tuner replaced.
Dan
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Not able to select HD on my Wii setup screen
Well see if it happens again, it may have been a one time thing. but try reconnecting the AV cables to the tv or change the picture settings on the wii setup options.
But this is important, is the picture grainy, or is there vertical black lines? if its black lines, i have the same problem and the only way to fix it is to send it to nintendo and theyll give u a new console. its due to overheating and the graphics card gets fried
Sep 02, 2008 | Nintendo Wii Console
Pictures are "grainy"
This may work, remove the batteries to try to "reset" the camera.
Jul 03, 2008 | Fuji FinePix S5700 Digital Camera
Video
Hi, the best thing you can do is to buy a 1 or 2 Gigabyte SD Card. Taking videos is at about ~100 MByte / minute. So if you take a 1 GIG-SD Card you may take ~10-12 minutes video or at a 2 GigByte SD Card you may take ~20-22 minutes (pure video).( But you may change to still picture in the meantime as you like).
Putting in the SD Card, swith on your camera, choose the video mode and push 'LCD Mode': there you'll see the info "R 22m47sec" on your LCD on the upper right position - for example.
This is the review-function and is your best way to check your video (while choosing the review-position on your wheel and than push the "6 o'clock"=review button on the camera and your video will start.
Have fun, you're also able to use the zoom-in while taking videos.
The DMC TZ1 is a beautiful camera.
Rolf
Jun 13, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Canon PowerShot A630 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
