Question about Honeywell DR4500 Truline Circular Chart Recorder
Config error on power up
Error E2011 Memory Config
It sounds like the servers have different memory modes selected :)
Mar 04, 2014 | Dell PowerEdge 2950 (becwfk1_6) Server
Help. have starimaster 4600cl getting "config rqrd" error
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Nov 23, 2013 | Stairmaster 4600 Cl Cordless Freeclimber
Sc 5100 beeps on startup
These are EACH... DIFFERENT SYSTEM CONFIGURATION ERRORS at boot
Check that you have not changed any hardware/added any hardware and that these changes were/or have not TAKEN EFFECT yet
Power down system.... use CMOS RESET pin config jumper to reset your boot configuration(s) changes
Multi-"BEEP" error messages are usually connected to RAM CONFIGS. and I would suggest uninstalling ram chips..... but ONLY AFTER FULL SYSTEM "power drainage"!!!... i.e. pulling power plug from your PSU, removing system battery or unplugging it's terminal wiring mobo connector, and pressing the POWER BUTTON on your system
Jun 04, 2013 | Computers & Internet
Error code 1 - reconfig message
Corrective Action
Feb 08, 2011 | Stairmaster 4400CL Stepper
Error message: Config Required. How do I perform this procedure? Thanks, Dennis.
Corrective Action
Dec 30, 2010 | Stairmaster 4400CL Stepper
Error Messag CONFIG REQUIRED. How do I configure?
Corrective Action
Receiving error message "config. RQRD", what does it mean and how do you fix it?
Corrective Action
Sep 01, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Tray Error - Invalid Config
Unplug the power cord well the printer is on. and it should reset it worked for me. Hope that helps.
Apr 25, 2007 | Dell 3100cn Laser Printer
Honeywell DR4500 Truline Circular Chart Recorder Logo
27 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Brandon Berry
Brandon Berry
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
