Question about Whirlpool Duet GHW9150P Front Load Washer
After pressing power button and pressing start button for a few seconds the Whirlpool Duet Washing Model # MCD-WFW9450WW00 machine will not always start. When it doesn't start the indicator lights blink. I need to shut down the machine and turn the power off to retry. Sometimes several times. I found that the door latch is slightly loose causing it to slide. I tried to tighten but to no avail. I'm not sure whether this latch is supposed to be loose or tight. The problem is occurring more often.
3 Suggested Answers
  • 19 Answers
SOURCE: Washing machine won't start
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Posted on Nov 16, 2008
oldTech2332
  • 2341 Answers
SOURCE: we have a whirlpool duet washer that flashes F11
The F11 error code means that the motor control unit& the central control unit aren't communicating with each other
It could be a loose wire connection between the MCU/CCU or either one could be defective
Gene
Posted on Jul 30, 2011
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
Whirlpool control locked
Power shd be on. Press and hold "end of cycle" button for 3 seconds. Always wait for 2 minutes after the wash is over for the machine to release the door lock; an inbuilt safety device. Never force washer doors, you'll have probs.
Check out your filter too.
Feb 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer won't power on
push in the end of cycle button hold for a few seconds
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Whirlpool duet washer
Press and hold the end of cycle button for 3 seconds..
Jul 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Front Loader - whirlpool - does not star
machine controls may be locked. Power on the unit and hold in the far right button for 4 seconds and then try to select settings and cycles
Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
