Question about Water Heaters
Amtrol boilermate er3 code - Water Heaters
2 Suggested Answers
SOURCE: ER3 no hot water
Er3 means that the water is being heated for more than 1 hour without reaching the set temperature.
Need new aquastat.
Posted on Dec 28, 2010
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Boilermate er3
is it an electric or gas or oil fired. Er3 means it is not getting up to temperature within the required time. Electrical - element bad. for oil or gas, no ignition or fuel supply.
Oct 28, 2013 | Amtrol ST-120V-C THERM-X-TROL ASME...
What does an error code ER3 tell me?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand.
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Oct 09, 2013 | Amtrol 2775S5009 60 Gallon WHS-60Z...
Noticed the circuit panel is blinking the code Er3, what does this mean?
CAUSES
-bad sensors
Sep 02, 2013 | Amtrol 2704E76 WH-7C Premier Boilermate...
Boilermate wh-7l, thermostat
Your BoilerMate obtains its energy from the home's boiler and does not have a reset button itself. I work for Amtrol, the manufacturer, and can be of assistance with more info. What is the problem you are experiencing?
May 28, 2012 | Water Heaters
No hot water have amtrol boilermate. boiler works fine to heat house just not hot water
There is a device on the boilermate called an aquastat which controls the flow of hot water into it. Replace that and you should be up and running again. Joe.
May 23, 2010 | Water Heaters
ER3 no hot water
Need new aquastat.
Sep 28, 2009 | Amtrol ST-120V-C THERM-X-TROL ASME...
Amtrol Boilermate makes whining noise
I had also this problem before, same with buzzing sounds on my Amtrol Boilermate and all I had to do was to call the local dealer and they have got it fixed.
May 05, 2009 | Emerson Part UWL Chrome Ultrasystem water...
No hot water from the Amtrol Boiler Mate model wh7p
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Mar 09, 2009 | Water Heaters
Water Heaters Logo
161 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
