Question about American Standard Heating & Cooling
Ice built up inside unit
About 6months ago inside unit was not cooling and ice built up inside unit, technician cleaned inside unit and it worked for another 6 months, now the problem is back all over again. Do I need a new unit?
    Genius:
  • American Sta... Master
  • 1,363 Answers
Could be low on freon or contactor stuck on compressor
Posted on Sep 06, 2015
kstfas
  • 75 Answers
SOURCE: Friedrich air conditioning - inside unit ice build up
Hi, Reduced air flow, low on freon or being continuously run during cooler weather such as at night. Some people turn their thermostat on 60 thinking that it will help get it cooler faster. They freeze up at night and don't get a chance to thaw during the day. It needs set no lower than 75 or so. The evaporator may be dirty. Don't know a lot about your particular unit but if the outside unit has the compressor and refrigerant lines running to it, The large refrigerant line should sweat all the way to the compressor if its fully charged. Please rate me if I have helped. Good luck kstfas
Posted on Aug 28, 2007
Illeagle
  • 525 Answers
SOURCE: Gold Star window A/C R5207Y3 Evaporator ice buildup
This is njormally an issue with oversizing but this should have manifested itself the 1st time you used it, unless you have relocated the unit. If you have reinstalled it in its original location and if you have cleaned the coils as required, then you have a low freon issue that only a professional should resolve.
Tip: If the ice is building up in 1 small area and not evenly across the complete evaporator coil, then you definitely are low on freon.
Posted on Jun 11, 2008
meBNme
  • 334 Answers
SOURCE: Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Posted on Jan 14, 2009
louislevel_2
  • 374 Answers
SOURCE: Formation of ice on evaporator element
hi! there,
eventually ice freezing evaporator occured two factor you have
dirty fin evaporator and undercharge system.
1. undercharge can easily detected using clamp
ammeter clamp on one line of evaporator while running
read the amper the compare this to yuor service
manual the rated current of the compressor.
2.if the reading current is below the rared current on
manual or there is tag on the body of unit specified
rated current.your unit need to recharge.
if has the same current no change at all freon is still
good, this only need cleaning of eveporator fin.
clean this by pressurise water to purge out all debris
particle on fin tube of evaporator.
cracking sound usally made by blwer or fan
misalignement or distorted bearing blower .
regards have anice day dont forget to rate me.
Posted on Apr 10, 2009
  • 588 Answers
SOURCE: My KOLIN window type remote control AIRCON is building up ICE
If you already had the coils and filter cleaned and the blower is OK, that only leaves the refrigerant charge.
You are probably low on refrigerant.
Posted on Aug 25, 2009
Water (and ice) in storage bin.
What is the model number?
Jul 07, 2013 | U-Line Icemaker
Freezer fan dead?
Could be the defrosting that is not working. The fan starts touching the ice build up on the back that then causes the noise. A few days later the fan will get stuck on the ice as it keeps on building up due to no defrosting taking place. Unit will keep running as the set temperature inside the cabinet cant be reached because the air distribution will get blocked of due to the ice build up and stuck fan.
Oct 06, 2017 | Northland 24" Built In Top Freezer...
I purchased a used taylor 754 about 6months ago i never try to use it...last month i passed the city and health inspection...i unwraped the used taylor 754 machine and plug to the outlet and light...
That's a low mix light. It tells you that you don't have very much ice cream mix left in the hopper. There is a sensor in there that when no mix is touching it, it turns that light on.
Jul 24, 2017 | Taylor 632-27 Ice Cream Maker
Hi, My refrigerator has been working perfectly for ten years. A couple of nights ago I noticed that it had wasn't freezing the ice and water dripping down inside the freezer part at the internal of the...
peter if your unit doesent seem to be cooling and the commpressor sounds like its running sounds wierd but make sure the fan cooling the evaporator coils is running if there is a lot of dust also clean the coils just a thought
Apr 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer light flashing
if you have ice built up on rear wall of freezer section then your unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow over to the fresh food side.
Jun 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Breezair unit icing up
hi there,
in this case thermostat is not functioning if this a no frost or frost free,if the fans inside is not working too.feel if air is blowing,if no blowing of air inside freezer,fan is defective,try to check fuse on the line goin yo fan there is fuse there,replace fuse.also check thermostat if functioning,if you can disconnect thermostat,disconnect it check this by soaking into ice bucket with ice the filler bulb of thermostat,the two terminals hook it by multitester setting to R1,observed the deflection about 12 minutes if the pointer does not deflect to high resistance this thermostat is defective replace.this should be done by a/c technician.have a nice day,dont forget to rate me ,thank's
Apr 24, 2009 | Heating & Cooling
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
The water is running but ice cubes made one at a time and very slow
Hi!!! You have high hard water built up in your evaporator you need too clean the unit.Put a cleaning solution inside..A dirty Evaporator also clean your condensor coil..good luck..
Jan 21, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
