Pn51e450a1f wall mount screws
What is the size of the screws that go onto the back of the t.v. to connect the wall mount arms?
  • 92 Answers
SOURCE: what size screw for holes on back of set
go to this size to figure out the screw size. http://www.tvwallmountguide.net/
Posted on Jun 18, 2009
  • 9 Answers
SOURCE: purchased universal wall mount kit for Samsung LN46B530
I have found that Home Depot and Lowe's (the bigger hardware stores) do not carry something like this. I alway got to my Local ACE Hardware where they have a whole isle with nothing but screws, nuts, bolts and fasteners. I always find what I am looking for there. So if you have a little hardware store in your area then I suggest trying them. It is alittle more expensive than the bigger guys but always worth it cause you can buy one, Two or 100.
Posted on Oct 03, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 01, 2010
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: Can't find screw size to
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Posted on Jan 14, 2011
Can I buy screws to fix base onto my umc tv
Yes The screws that you took off the back of the tv mount on wall brackects mounted on the back of your TV should be the same size
6mm
Oct 23, 2014 | Televison & Video
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
