everything seems to be working, the filter is clean, nothing is blocked, but it isn't collecting...
(More)
everything seems to be working, the filter is clean, nothing is blocked, but it isn't collecting water. No heat is being generated from the vent.
Fan will run constantly. Compressor will come on for about 3-5 seconds then kicks off. Temp is 70...
(More)
Fan will run constantly. Compressor will come on for about 3-5 seconds then kicks off. Temp is 70 deg, with 55% humidity. One wire was badly corroded at what I assume is the humity sensor. Fixed that, didn't help problem.
This unit is a little over 1 year old. It worked fine last year. I put it away for the winter and...
(More)
This unit is a little over 1 year old. It worked fine last year. I put it away for the winter and took it out a couple of weeks ago. It has stopped collecting water. I cleaned the air filter and tried running in all the different modes and nothing. I tried another dehumifier and that one works, but the Soleus does not.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
