Question about Vacuums
How to assembly the bissellpowerforcevacuum
I can"t get hose to go on
How do i replace a valve assemblyon a hoover widepath f6020
You don't need a new hose. Remove the two Phillips head screws which hold down the wand cover. Be very careful when removing these parts. Pay close attention on how these parts are assembled. They are spring loaded and will fly out the end of the hose assembly when the cover is removed. The wand valve assembly or the nozzle valve assembly or usually the parts that break. Vac Parts Warehouse Here is a link of the parts breakdown.
Oct 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Hoover max extract leaks from end of upholstery hose
Hello! The nozzle/valve assembly, the white piece at the end of the hose that releases the solution may be clogged with build-up residue. Try soaking the trigger end in warm water for a few hours. If this does not help, the nozzle/valve assembly may need to be replaced. Order the nozzle/valve assembly by following this link. Search Results or order the complete hose assembly by following this link. Search Results
Hope this helps!
Jun 06, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do i remove the old hose assembly non my simplicity 7350 so i can install the new part? It seems to be locked in tight, do i break the tabs?
Are you just trying to put the hose into the cuff? If so, you just need to know that the cuff is threaded so the wire of the hose fits in the threads. If you're asking about the assembly at the top of the hose--I don't know. Probably you have to take the green shell apart and work from the inside. Good luck.
Sep 12, 2010 | Simplicity 7250 Deluxe Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
My hose cracked on my ep238
I've had the hose brake on this vac at both top and bottom several times. You can pinch the ears that hold the hose assembly to the wand and vac connection and get at the piece that the hose screws into. Remove the old piece, cut the hose cleanly and screw back in, then snap back together. They don't seem to have this hose anymore and since the vac also has problems with its cord assembly I'd say your best bet is a new vac once the hose can't be fixed anymore.
Apr 13, 2008 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
