Duo therm model 75003-0
Does this unit use 170 or 190 degree thermal disks for the fan
22yooper
  • 828 Answers
SOURCE: duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Posted on May 31, 2008
22yooper
  • 828 Answers
SOURCE: duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Posted on Jun 28, 2008
motor1258
  • 6674 Answers
SOURCE: Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
Posted on Aug 14, 2008
  • 659 Answers
SOURCE: Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Posted on Apr 13, 2009
SOURCE: I have a dometic duo-therm. No air coming through ducts.
I have a new Montana Mountaineer with a Dometic Duo Therm as well and experience something similar.
It appears that there are two options:
1. Open the vents in the unit and all the cold air will blow out of the AC as that would be the shortest path and the there is hardly any air coming out of the ducts.
2. Close the vents in the unit and it will force all the air through the ducts.
We let the air blow straight out of the unit during the day and then force it through the ducts at night to force it in the bedrooms. You could also open the vents in the unit part ways to get a combination.
I didn't figure it out immediatly either, but just look close at the unit and you can see that you can close the vents on the unit itself
Posted on Apr 20, 2009
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Replacement Fan Motor
Try Johnstonesupply.com. Use the information you provided above.
May 06, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm fan only runs on low
useually a sticking fan relay in the controll board this is the closeest unit to a home based cenral air system and i would leave this one to the experts if you want to trouble shoot there is a detailed wiring diagram on the back side of the pc board cover on the fan and compessor unit it self there is a seperate relay for each speed on your unit make sure getting power to selected relay if not trace wiring and do continutity tests back to themostat
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
