Question about Refrigerators
Ge Profile Refrigerator side by side psi23sgna bs
11 year old unit is making a clunking sound when motor / condenser shuts off. Your thoughts.
SolutionGuy
  • 331 Answers
SOURCE: GE SIDE BY SIDE REFRIGERATOR
Kay, these are known for having faulty evaporator fan motors (failed motor bearings). This is what has failed in your fridge. This is a tedious and time consuming repair, you may want to purchase the evap motor and hire someone to install it for you. Just one of the reasons I recommend this is that 50% of the time, the new motor's wiring harness will not match the harness on the fridge and so must be converted to adapt. The evaporator fan motor is the fan inside the freezer, behind the back panels. If you choose to repair it yourself, UNPLUG THE FRIDGE FIRST! Then remove all items from freezer. Remove all shelves and bins. Remove the ice bin. Remove the lower back panel. You should be able to see the motor now, but you can not access it yet. The motor is mounted in a plastic shell/housing, this entire housing must be removed (along with the related wire harness). Install the new motor and rebuild the unit. This doesn't sound like much, but since you've not done one before, figure 2 1/2 to 3 hour job time. (With practice, it still takes us ~50 minutes) Wiring is CRUCIAL! Take note of EVERYTHING and the way things are routed in there. Otherwise, you won't know if you did it right until you have it rebuilt and plugged back in, if something were mis-wired... you'll know it now. Then have to disassemble to locate the problem. The part number you'll need is #WR60X10185, and sells for ~$45.00 at your local appliance parts retailer. If you hire someone to perform the labor, they won't be able to "soak" you on the part price. The good news is that after the repair is complete, your fridge will cool better AND I've never had a callback on these! (Which means that the replacement motors are MUCH better than the original factory installed ones.)
Posted on Aug 11, 2007
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
SOURCE: Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Posted on Apr 18, 2008
SOURCE: Compressor makes "clunking" noise when it turns off
No I did not get any replies on my GE Profile refrigerator problem. Your question said "Amana".
Posted on Jan 20, 2009
mastatech
  • 478 Answers
SOURCE: refrigerator makes loud noise when motor is shutting down
Check for dirt, vacume throughly. Visually inspect fan blade, for anything not normal.
Posted on Mar 11, 2009
I have a GE GSL25IFRF-BS side by side and I was having a problem with the water and ice dispenser so I unplugged the unit. When I plugged it back in the unit would just click and sound like it was trying...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile Perf high pitched sound coming from back
First check the simple: may just be dust and pet fur clogging up the airway making it hard for the condenser fan to draw ... or condenser fan bearing is wearing out.
Jun 28, 2010 | GE Profile Performance 23.5 cu. ft....
I have a GE Refrigerator model PD520SFSBRSS that
Strange sounds can be deceiving as to their actual location. Your problem could be one of several:
* icemaker
* freezer fan motor
* compressor
* condenser fan motor
Contact an appliance service company.
Feb 15, 2010 | GE Profile PDS20SFS Bottom Freezer...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 17, 2009 | Amana ARSE66MB Side by Side Refrigerator
GE side by side refrigerator has stopped working...
sound to me that the unit may be stuck in defrost. look for the time clock and or if it is a newer unit check your condenser coil it may be dirty. the unit may also have a leak on the refrigeration side of it.
Dec 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator makes a clunking noise when the compressor shuts off.
My GE Profile about 15 yrs old is also clunking.. fixed about 4 yr ago and doing it again.. Think the compressor motor is loss and when it shuts off it vibrates.. any other solutions please post if you had it fixed..
Dec 18, 2008 | Refrigerators
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Apr 17, 2008 | Refrigerators
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
