Question about Exercise & Fitness
Horizon T507 treadmill control panel does not light up even though the neon in the on/off switch illuminates
SOURCE: Erratic speed on Horizon treadmill.
Treadmills Erratic speed on Horizon treadmill. Solve Hi The speed of the treadmill does not correspond to the speed control key. Any... (More)
Posted on Jun 03, 2009
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a Horizon elite 507 treadmill, everything
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
Posted on May 23, 2010
Testimonial: "Many thanks for prompt response, seems that the treadmill works only when in the upright position and not the horizontal as per normal. Gonna have to learn to run up walls i guess"
maxtreadmill
  • 832 Answers
SOURCE: Horizon Treadmill T5.1. A sudden vibration and
To find a specific bearing that has gone bad in a treadmill you can use a long handled screwdriver and touch it to a non-moving portion of the rollers and then put your ear up to the handle and the screwdriver will amplify the noise of the part so you can find out which part is making the noise. If it is a bearing, it will be obvious which part is the problem because the grinding noise of the bad bearing with be amplified by the screwdriver.
Posted on Jun 11, 2010
SOURCE: horizon treadmill won't start running
power going to treadmill. it is beeping the whole time but wont start or move
Posted on Jun 14, 2011
RST 5.6 won't start
Does the upper display illuminate?
If so, when you press start do you receive an error code on the display?
If the console illuminates, you press start and the machine will not run, the most common failure is the motor control board (located in the compartment with the drive motor)
Nov 24, 2013 | Horizon Exercise & Fitness
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
Dec 26, 2010 | Horizon Fitness Horizon Motor T51...
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
The treadmill powers up but the belt will not work
the motor controller has failed and will need replaced
Aug 01, 2010 | Horizon Fitness Merit Fitness 725T...
My Uncle gave me a Horizon T605 treadmill and the
horizon rct 7.6 , safety key off , replaced ,key.reed switch and board , still says safety key off ?? spoke to horizon several times and repair techs as well ,it can only be 1 of those 3 items , all switch & key tested good , must be a faulty new board ?? could it be anything else ??
May 28, 2010 | Exercise & Fitness
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
I have a T54HR horizon treadmill. The problem is
best if you see the local retailer where you bought the treadmill. Obviously the switch, whick is a magnetic disc is not activating the sensor in the control panel and need to be looked at.
Sep 23, 2009 | Horizon Exercise & Fitness
Apr 18, 2009 | Horizon Exercise & Fitness
Exercise & Fitness Logo
16 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
