Question about Tascam Dp-02cf Digital 8-track Recorder
TASCAM DPO2,CHANNEL 1 WILL NOT RECORD, CHANNEL 2 STILL STILL RECORDS PROPERLY. ANY ADVICE?
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
Being older I recall these recorders. The problem with them was 8 track tapes never played very well due to the cinnamon roll design, the recorder and players tuck the tape back into the center of the roll when playing them. This poor design causes them to wear out fast and often snag or damage the mechanisms. Not to mention you can often hear adjacent tracks spilling over into the current track you are listening to...
In your case I think the recording head which records track two is out of allignment or contaminated with oxide from the tapes which tends to cake on them. You might try giving it a blast of compressed air if you can find the recording heads, or if unafraid cleaning the head witha q-tip in denatured alcohol or a commercial head cleaning solution for old magnetic tape machines, the solution is basically alcohol and something like freon to make it evaporate if I recall correctly.
If it still doesn't work it is probably because these things are very old regardles of how well they were made in addition to the fact the technology is 40+ years old.
Posted on Mar 16, 2014
4 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: mini disc recorder question
Just use the first two tracks, one for left and one for right and use the PAN pots to adjust the stereo positioning. Just run the 'tape out' or 'line out' or 'aux out' of the mixer to the REC "IN" on the MiniDisc recorder; hit "record" then the "play" button to start it. Make sure your input selector switch is on ANALOG and not DIGITAL or OPTICAL. Let me know how it works out for you. Okay? Thanks
Posted on Nov 06, 2009
SOURCE: How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Posted on Feb 20, 2010
straydogger9
  • 16 Answers
SOURCE: tascam 8 track recorder won't play back recording
You must be missing a step somewhere. I suggest you CAREFULLY read the manual again and follow it step by step. Recording is simple on this unit once you do it a few times and get the procedure correct. Good luck
Posted on Mar 01, 2010
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
May 31, 2010 | Tascam HHB DA30 Tape for DA-88
When i record and try to play back i get nothing dpo2 . 2 tracks armed. i stop rewind and play and theres nothing , headphones can be heard when recording
Very likely the over-write head does no longer function properly. Try again with a MD that already has recordings on it, try to record another track to it. If the entire disc seem blank after TOC was written, the OW head is bad. At this point the unit effectively becomes a player only....
Mar 10, 2010 | Tascam Audio Players & Recorders
I have a DP2 Tascam 8 track recorder. Can I come out of my 16 channel mixer into my recorder and record my whole band?
The Tascam DP-02 can only record two tracks at a time.
You will have to mix "on-the-fly" and record the master out, or record each instrument seperately, and just record the drums as a stereo mix.
Feb 13, 2010 | Tascam Starter Pack for 4-Track Cassette...
TASCAM WONT BOOT UP
If it's still under warranty, take it back if it does not work properly.
May 12, 2009 | Tascam 2488 Portastudio Multitrack...
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam dpo2 not burning a cd
You need to create a master first before you can burn it to a CD.
To create a master you'll need to set an 'OUT' point, then enter mastering mode (by pressing the master key so that it flashes) and then record your master by holding record and pressing play. The master recording stops automatically when it reaches the out point (the in point is always zero). The steps for creating a master are outlined on page 27 of the manual. Setting the in and out points can be found on page 30 and burning the master to CD is on page 67.
Hope this helps.
Cheers.
bd.
Dec 20, 2008 | Tascam DP01 All-In-One Recording Package...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
I need more tracks!
Your preamp needs to have 1/4" output jacks which channel all of the mic inputs into these two outs. This isn't typically how a mic preamp is set up however. They often will have 2 ADAT outs which output all the inputs in stereo or some other configuration. You may have one that can do this, but if not you'll probably end up needing some kind of basic external mixer which can handle all of the individual outs from your preamp through the mixer's inputs and then you'd run the main outputs from your mixer into the two inputs on your Tascam DP-01.
Mar 31, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam Dp-02cf Digital 8-track Recorder Logo
71 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
