Heating & Cooling Logo
A
Anonymous Posted on Feb 07, 2014
Loud buzzing sound on XV95 Trane furnace - Goodman Heating & Cooling
  • Lou Barta Nov 28, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
1 Related Answer
Anonymous
  • 52 Answers
  • Posted on Dec 19, 2009
SOURCE: New Trane XV95 furnace runs and stops nine
if it is a mechanical thermostat the heat ant. does that on cheaper digital tstats it is set by span and on better stats like honeywell model 5000,6000,8000 series you set the cycle rate. what kind and model number is tstat
When thermostat calls for heat, loud buzzing
That sound generally comes from a magnetic coil that is being energized. It could be from a compressor control or a furnace gas valve. In either case there is no danger involved it may buzz for years and unless you have money put aside for a heating mans adventure id just let it buzz until it gets so loud it just has to go. Sometimes the buzz just goes away. I know it sounds crazy and I understand one persons buzz is another persons nightmare. Its yer call. Hope this helped and good luck.
Trane xv95 converted to propane is on system lockout
worth checking over heat temp sensors (klixon ) sensors can cause heater to go into a cool down purge Through an open circuit heat exchanger (Klixon ) temp sensor Ive seen before good luck
There is either a problem with the ignitor or the flame sensor.
1helpful
Is goodman a good furnace? What about if I compare it to a trane furance?
goodman makes a very good furnace and just as durable as a trane at a fraction of the cost. i'll stand behind goodman just as i would a trane.
When the furnace comes on after recovering from low thermostat setting, we can hear a loud noise, something akin to a wooden bead that's being blown around inside the unit. Once temperature is reached, the...
Could be correct, or you may have something in your fan that either fell into or crawled into your fan through the exahust duct.Since you have a service contract, have they actually been out to look at it or did they tell you that on the phone. It might be worth removing the fan and clear any forign matter. The problem is the labor to do that would be the same as to replace it. What does your service contract cover??
Trane XE90 both ac unit and the furnace kick on at the same time
How about the Heating/cooling thermostat. Sounds like you better check it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
