Question about Konica Minolta Office Equipment & Supplies
Trouble reset - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
For what model and what code???????
Posted on Jan 23, 2016
I have a konica minolta bizhub C454e I want to insert the IP but when I enter the administrator option I can not find the Network Settings ... what can I do?
You can try trouble reset.
First you need to switch off the copier, then hold the yellow reset button and then whilst holding it power up machine. Hold reset until you get white screen with trouble reset in middle. Now tap on the trouble reset button and it hould point down an arrow saying OK. Now shut down the machine again and leave it off for at least 10 seconds. Boot up machine and try to access the network settings.
If this doesn't work then you may have to call a service engineer to reset it in Service mode.
Sep 23, 2017 | Konica Minolta Office Equipment & Supplies
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
Bizhub c352 reset cod?
Trouble Reset
Turn off the machine, Now press "utility/Counter" Now turn the machine ON.Keep the button pressed. Trouble reset button will appear on screen, press it and restart the machine.
May 28, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub c353 code 2151 can't reset the code
Open the front door and close it.
Restart the machine.
Press utility/counter button and keep it pressed, now restart the machine.Do not release the button until the trouble reset option appear on the screen.Hit the trouble reset button then restart the machine.
Nov 29, 2012 | Office Equipment & Supplies
Hi, I have a Konica Bizhub C451. There is a trouble code C-3824.Any advice to resolve the issue? Thanks Chris
Chris,
Turn off main power inside front cover insure that the sub power switch is pushed in on right side of the control panel. Hold down the Utility/counter button and turn on the machine hold down until screen shows trouble reset touch trouble reset go OK. Power off then wait 10 seconds power on. If the code comes back do not attempt another reset you are resetting the code for the fusing unit (The hot Part) It can catch on fire and that would ruin a perfectly good day! Have a technician look at it Good chance fusing unit needs replacing
Nov 03, 2010 | Konica Office Equipment & Supplies
How to reset the copier after installing the new imageing unit c350
Normally it has no need for reseting.
In the moment you put the new image unit it resets the counter life, although you can reset by holding down the trouble reset button and in the screen you will see trouble reset.
touch it and switch in and off the machine with the main power button.
May 15, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
CPI Trouble Light will not Reset
Try to check the line if it is correctly installed to the proper area. maybe your battery doesnt have enough power to comply the proper amount of your system.
Dec 22, 2008 | Computers & Internet
C0500 Code in Dialta 3010
Clearing C5XX codes on Minolta Di2010/2510/3010/3510:
1. Push Warm Restart button (small button on right side of control panel. A small dot should appear on the left edge of the touchscreen.
2. Enter "3" on the keypad. This should get you the Initialize menu.
3. Select "Trouble Reset" at the bottom of this menu.
That should do it.
Jun 12, 2008 | Office Equipment & Supplies
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
