Question about New World G60m Gas Single Oven
Appears to have no power - New World G60m Gas Single Oven
APPEAR THE LETTERS PF IN THECLOCK CONTROL
usually, just reset clock..it stands for power failure..if power goes out. they all do this...
Feb 16, 2011 | Ovens
E1 -F5- Error code appears when attempting to start self-cleaning mode.
F5
- E1 Self clean latch will not
lock
1.
If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes
Dec 04, 2010 | Whirlpool RBS275PD Electric Single Oven
When I try to set a temperature, F9 appears. I have tried to turn off power by flipping circuit breaker. The power was off and I set a temp, then turned it off and F9 appeared again with "lock." Any...
The most common cause of a F9 error code is a problem with the door latch circuit. There could be a pinched wire for the circuit causing a short or the door latch motor is defective. Sometimes a problem with the ERC can cause this error to appear. Possible problems can very slightly from manufacturer for this error code but almost all use the F9 error code for the oven door lock.
Jan 14, 2010 | Ovens
I have a Whirlpool stove (model# RF385PXE)and I tried to start the self clean oven cycle the letters "door" appeared along with "E1" and "F5". The door is closed all the way. I even tried pushing it closed...
HI. This code is an indicating that the Self clean latch will not lock. Lock mechanism failure. follow the procedure below to address further.
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Nov 16, 2009 | Ovens
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
FSE7 appears on kitchenaid built in oven
Here is the fault code for F5:E7...
1. If door latched:
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
Sep 16, 2009 | KitchenAid Ovens
Kenmore gas oven continuously beeps F-5 when on. I have to cancel and not use. Please help.
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match.
If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part.
If connections are not damaged, reconnect power and hold down any key until the F5 error clears.
Once the F2 code appears, select 'cancel' and observe for one minute for errors.
If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part.
If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective.
If corrections are made during any step, power should be reconnected and the unit should be tested.
Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors.
If error continues, disconnect power and replace control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 23, 2009 | Kenmore 47732 / 47734 / 47739 Electric...
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 | GE Ovens
F7 SHOWS UP ON THE SCREEN
this problem just occured to me last nite. we had to shut the power off at the breaker box. we turned it back on this morning and it seems to be working fine. it is still a mystery as to what occured but it appears it had to reset itself. not sure if this is a solution, but it has appeared to be working so far.
Nov 23, 2006 | Kenmore 33464 / 33465 / 33469 Gas Single...
New World G60m Gas Single Oven Logo
29 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
