Question about Cherokee AH-27F (40 Channels) 2-Way Radio
Battery pack rechargeable - Cherokee AH-27F (40 Channels) 2-Way Radio
What kind of charger does this Kodak Dashboard CW330 take?
The original battery pack is nothing but 2 AA batteries held together with a plastic holder, you can use regular AA rechargeable batteries and save some money. I had a similar camera with the original battery pack held together with some plastic holder, I simply substituted that battery pack with 2 regular rechargeable common batteries and camera works the same.
Mar 03, 2015 | Kodak Cameras
My GRE PSR295 scanner wont switch on
first off check your batteries. if you are using a rechargeable battery pack disconnect it and try it off the power supply alone bad battery packs can and generally do keep radios from powering on. If this allows it to come on, try charging it for 24 hours, and then deep cycling it several times ( run the scanner with sound such as on a noaa weather channel) until it goes dead and then recharge, to recondition the battery pack. if this doesn't work the pack will need to be replaced or rebuilt (batteries plus can do this) if the radio just uses discrete rechargeable batteries simply replace them. meanwhile I'll look for a manual for you....
Here you go
http://www.manualslib.com/manual/703072/Gre-Psr-295.html#manual
Feb 16, 2015 | Radio Communications
I have a pair of walkie talkies, rechargable, but one of them wont work with the battery pack. Both battery packs work in the other one, but this one will only work with 5 AAA batteries. Any ideas out
If your rechargeable battery pack takes a different battery tray than the alkaline, you possibly have a bad connection in the battery tray. If they appear to use the same battery contacts, look at where the rechargeable battery touches compared to the alkaline. There may be a problem in this area. Clean all contacts with a pencil eraser to insure your radio is free of debris on the contacts.
Best regards.
Feb 24, 2012 | Columbia Telecommunications Group Radio...
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Fuji s3 does not turn on...
You have done the right thing, so far. That which I would first have suggested. Congratulations! You would be surprised how many persons ignore the need for fresh batteries.
Yes, the camera should now be reset, and if that fails, service is required to make certain of your investment.
However, the battery must first be determined to be an actual Fuji battery, and if not, this is not your fault.
Please read the following:
Recommendation for Use of Genuine Lithium Ion Rechargeable Battery Pack for FUJIFILM Digital Cameras Thank you for using Fujifilm Products.
It has been our policy to recommend that the genuine Fujifilm rechargeable battery pack be used for Fujifilm digital cameras that use a battery pack.
However, it has been confirmed that there are certain counterfeit battery packs available in the market that look very similar to a genuine Fujifilm rechargeable battery pack.
Some of these may not comply with safety standards, they may cause serious problems, such as overheating, leaking, bursting, or fire.
For your safety, we would like to remind you to only use genuine Fujifilm rechargeable battery packs for Fujifilm digital cameras.
Please note that Fujifilm will not accept responsibility for any camera problems, accidents, and damage of any nature that may occur due to use of non-genuine Fujifilm battery packs.
We appreciate your kind understanding and cooperation in this regard.
FUJIFILM Corporation
Apr 07, 2009 | Fuji FinePix S3 Pro Digital Camera
Recharge batteries in camera on g610 printer dock?
Hi, I think I can answer your question, i just tried something with my camera and camera dock.
My camera came with a Kodak battery pack(pack that looks like 2 batteries connected together). When I place my camera with this battery pack in it on the dock, a green light comes on on the dock and the batteries begin to charge. However, when i place any other rechargeable batteries in the camera on the dock, it has no effect, my theory is that it must be a battery pack, possibly by the same manufacturer so that it will charge correctly
Dec 20, 2008 | Kodak EasyShare C613 Digital Camera
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Oct 02, 2008 | Televison & Video
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
FRS-14ND 2 way radio
Hello you can recharge the batteries only if the bateries you are using are rechargables, this could be Bat recharg. 2AA or 3AA or a pack.
Oct 01, 2007 | Columbia Telecommunications Group...
Cherokee AH-27F (40 Channels) 2-Way Radio Logo
29 people viewed this question
Top Cherokee Radio Communications Experts
ka4iup
ka4iup
eradiostore
eradiostore
Mike Charette
Are you a Cherokee Radio Communication Expert? Answer questions, earn points and help others
