Question about Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor won't stay on - Fuji FP-988D 19" Flat Panel LCD Monitor
Monitor button flashes and repeatedly clicks but won't turn on screen
Tell me where on a laptop is a monitor button, first
Post back in a Comment
Regards,
joecoolvette
Mar 08, 2013 | Computers & Internet
HP LE1901W won't stay lit up
usually with lcds, this can be caused by a bad inverter or power supply
Jun 20, 2012 | HP L1710 LCD Monitor
Hp elite l2201x monitor won't work
I am experiencing the same issue. My monitor will not come out of sleep mode. HP informed me to purchase another power cord, but it yielded the same results. Any solutions????? Thanks
May 28, 2012 | Dell Computers & Internet
My monitor won't stay on
WOW another all in one problem. Looks like you are just about ready to be without a computer for a while. If you at least had things separate instead of being an all in one you could just plug another monitor and keep on rolling.
It sounds like either the LCD Inverter or the LCD Screen has issues.
Mar 31, 2012 | Sony VAIO VGC-LS20E Notebook
My desk top monitor want stay on
What do you mean won't stay on? Describe exactly what it is doing? When does it not stay on, when you press the power button to start the computer? You said it does not stay on, so that tells me that it comes on for a while and you are able to see things, right?
Mar 30, 2012 | E-Machines eMachines Desktop PC
My desk top monitor want stay on what could be the proble
Mar 30, 2012 | Computers & Internet
MONITOR WON'T STAY ON. not connected message then it goes off
Hook a spare monitor to the computer, if okay! problem in the original monitor, if both show the same symptom, it means the Video Graphics Card in the computer is defective. If possible change the video cord from the computer to the monitor, sometimes these cords fail.
Mar 13, 2012 | eMachines ET1641-02w (PT.NA60X.001) PC...
make sure the connection is tight
Dec 22, 2011 | Dell Dimension 8300 PC Desktop
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
My monitor will either stay on and wont' turn off (even if you click the green button)
your Mnotitor Panel Switches gone bad replace all the switches and your monitor will be ok.
Ashok
Jun 08, 2007 | HP Compaq FP5315 15" LCD Monitor
Fuji FP-988D 19" Flat Panel LCD Monitor Logo
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
rdjagger
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
