Question about Kenmore Washing Machines
When "start" knob is pulled, water starts running but stops.
Nitrotrike
  • 589 Answers
SOURCE: When I pulll the knob on the washing machine, their is no water not running out
Can you hear it "clicking" when you pull the knob (not the knob sound itself, but the water solenoid itself)?
If you can hear it, then make sure the machine has a water supply (hot / cold). You would be surprised at how many people accidentally turn off the water supply and forget about it.
Try changing the wash settings to cold/cold, etc (the opposite of whichever one you're using now) and see if it will fill.
Let me know the results, and I can help you further.
Posted on Jan 08, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 1028 Answers
SOURCE: maytag washer: knob
bad contacts in timer ..replace timer
Posted on Jun 02, 2008
hiltonjug
  • 612 Answers
SOURCE: Kenmore top loader 500 - water does not run when
Either a bad water valve or pressure switch. If you can't get cold or hot, it most likely is the pressure switch.
Please rate solution
Posted on Sep 04, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Hi, when pulling the select knob, no water, just the agitator.
Bad timer, the timer is not telling your system the correct setting and just jumping to a setting of its choice. Once the timer is replaced everything will work just fine.
Posted on Jun 01, 2010
Knob turns but no water comes out
On thi set up you have to pull the knob out to start the water flowing To stop push the knob back in . If that is not the problem you may have to replace the mixer
Mar 09, 2013 | Home
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Water won't cut off when filling... Hoover Galaxy A6834
Hi Steveb6723 ,Just read your posting.Now here is a little test I need you to preform so I can tell if the problem is your water valves or your pressure switch system.Now 1st turn it to a normal cycle and only select the cold fill.Pull the knob out so it starts to fill.Now turn the machine off at the power point,Does the water stop filling straight away?If it does select hot fill and pull the knob.When it starts filling on hot water turn the power off again and see if the water
stops straight away.Please reply and tell me if the hot or cold water continued to flow when the power was off.Looking forward to your reply.
Jun 24, 2010 | Washing Machines
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Jun 12, 2009 | Gaggia Syncrony Compact Coffee...
HELP ME WITH MY PROBLEM
if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
Dec 12, 2008 | Kenmore 22422 Top Load Washer
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
11 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
