Question about Sport & Outdoor - Others
Puck Battery size - Sport & Outdoor - Others
I have turned the grind knob all the way down, below 1.
Sounds like there is not enough coffee to make a solid puck. If you get crema, grind coarseness sounds ok. A finer grind will produce less coffee grounds for the puck and increases chance of clogging.
You may have to balance grind size with amount of crema to get solid puck.
Big problem with these is you want dark roast for espresso, but oil on beans clogs grinder. Are you using a dark roast? A medium roast works better in these. Or, can you increase the grind time? My Super-auto had a program option to increase time. But not in reg instructions. Got it from authorized repair facility.
May 04, 2016 | Saeco Vienna SuperAutomatica Coffee...
Replacement lid for wolfgang puck slow cooker
  1. Wolfgang Puck Parts‎
    www.wow.com/Wolfgang+Puck+PartsWolfgang Puck at HSN®‎ www.hsn.com/‎rating for hsn.com
    Wolfgang Puck's Cookware, Bakeware,
    Appliances & More - Shop HSN Today!
  2. Wolfgang Puck Cookware Lids‎
    when.com/Wolfgang+Puck+Cookware+Lids
    Explore Wolfgang Puck Cookware Lids
    Discover More on When.com!
Dec 16, 2015 | Wolfgang Puck Crock Pots & Slow Cookers
Have all in one electronic Wolfgang puck salt and pepper mill. I can't figure out hot to open the top to replace the batteries. It does not work like the electronic sets (is a bit different).
batteries are in the bottom. unscrew bottom cap and pull metal ring to release battery pack. put in fresh batteries and return to casing. screw cap in place. if it does not work immediately, unscrew cap again and move metal wire to opposite side of battery pack and replace the cap again.
Oct 13, 2013 | Wolfgang Puck Salt & Pepper Mill Set
What are the rules of Air Hockey?
Here are some basic rules as defined by the USAA:
  • A face-off or coin toss decides which player gets the first possession of the puck.
  • The first person to score 7 points by shooting the puck into the opponent's goal wins the game. When the puck breaks the horizontal plane inside the goal, a point is counted, whether or not captured by the electronic scoring device.
  • Once the puck is on a certain player's side of the center line, he/she has 7 seconds to hit the puck back across the center line. Otherwise a foul is committed and the opponent receives possession of the puck.
  • Placing one's mallet on top of the puck, known as topping, is a foul. Here the opponent receives possession of the puck.
  • A player cannot touch or strike the puck with any part of his/her body or with any object other than the mallet. Doing so causes a foul and possession changes hands.
  • If the puck is on a clear path into the goal and the player stops it with anything other than the mallet, this is goaltending. Here the opponent receives a free shot.
  • Hitting the puck when it is on the opposite side of the center line, or crossing the center line completely with one's mallet causes a foul. Here the opponent receives possession of the puck.
  • Red lines in the air hockey should not be crossed by the air hockey mallet. (Catalan Champion Chip)
  • If there is a red line on the goals, it means that you cannot keep the air hockey mallet behind the red line. (Catalan Champion Chip)
  • If the puck leaves the table, a foul is called on the player that caused the puck to go out of play due to offensive motion and the opposing player gets possession of the puck. Generally, when a player causes the puck to leave the table with a forward motion of the mallet, even defensively (known as charging), the foul is charged on them. An out of play foul results in the opponent receiving possession of the puck.
  • The players playing cannot touch the puck at any time during pl ay, but if one player scores they can put the puck in loser's side.
Jul 25, 2012 | Sport & Outdoor - Others
What's the puck made of?
Air Hockeypucks are slim discs made of Lexan polycarbonate resin. Standard USAA-approvedpucks are the yellow Lexan, red Lexan and the Dynamo green. In competitions, alayer of thin white tape is placed on the face-up side. Air Hockey pucks comein many shapes and s. The shapes could be a triangle, hexagon, or an octagon.
What is the official size and weight of the tournament puck?
The official puck should be 2.3125" wide and0.75" height. The minimum weight of a puck should be 310 grams and a maximum of350 grams with caps.
Jul 09, 2012 | Sport & Outdoor - Others
I just need to know what the size of the wolfgang puck electric pressure cooker rice measuring cup is. i lost mine.
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
A rice measuring cup can be purchased on-line; no information available on it's size.
Jan 26, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
Manual Wolfgang Puck #BPCR0005
Here is the site for this pressure cooker and model # that you need...
http://www.wpcookware.com/manuals.asp
It's on the left hand side under the panini maker...the picture is of the 7.5 size but under that picture it does have a drop down menu that says model # and that 5 qt Pressure Cooker with that Model # is there...
Good Luck
Shelly
Oct 12, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Dec 01, 2008 | Wolfgang Puck Stand Mixer
Sport & Outdoor - Others Logo
64 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
