Question about LG Kompressor Upright Vertical Cyclone Vacuum
Vacuum wont turn on - LG Kompressor Upright Vertical Cyclone Vacuum
Bissell 687C Vacuum wont turn on
Try to check the circuit... as when there is an circuit fault it gains high amperage and hence fuse shut the current till it regain. It happens to save your device.. don't be doctor. Get it done by authorized person or somthing or it will cost your more then your device cost...
Mar 15, 2014 | Bissell Vacuums
Brush Bar wont turn
Once you put it back together recline the vacuum as normal use and turn it on. If not working still the brush motor is burnt up. Needing replaced.
Feb 16, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
Unit wont turn on then wont turn off
when i put in the usb cable from the speakers to the lap top it dosent read it on the laptop end that something has been connected
Dec 23, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My dyson will not turn on
make sure electrical out let has 120 volts, try another out let if all is good.electrical cord at the plug in prongs could have a short in cord.the control switch could be faulty and make sure vacuum bag and cannister in place tight.i remember some of 1960s and late model electrolux vacuum cleaner if the vacuum bag container door wont closed all the way vacuum cleaner wont turn on.
Jan 23, 2012 | Dyson DY500 Bagless Upright Cyclonic...
My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Dec 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
LG Kompressor Upright Vertical Cyclone Vacuum Logo
24 people viewed this question
Top LG Vacuums Experts
Think Crucial
Think Crucial
Tim Venetis
Colin Stickland
Colin Stickland
Are you a LG Vacuum Expert? Answer questions, earn points and help others
