Question about Panasonic Workio DP-190 Multifunction Laser Printer
The error message is Tel. for P/M but we are still receiving and sending faxes
2 Suggested Answers
tech435
  • 284 Answers
SOURCE: Not receiving faxes
there is an in/out button beside the number 3 , it needs to be bright green to be working. just press it a couple times
Posted on Sep 22, 2008
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
pifonski
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
It's not sending or receiving faxes, but line is working
May I know what exactly the model that you have?
Initially, first check the settings of the machine if it was set to tel/fax or fax settings. Check if there was an error message appear on the unit or better to print out a copy of the fax transmission status. Fax machine will print out a copy of the transmission if it has a problem or it has a communication error on the line or in the other side whose receiving the a fax.
Kindly update me again here.
micro
Jul 28, 2009 | Canon FAXPHONE L80 Laser
Receiving problem
There are noises on the tel line,and then the fax receive too many errors and reset the tx or rx.
Jun 23, 2009 | Canon L220 Plain Paper Laser Fax
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Can not receive fax
Make sure the fax is set to receive automatically. The receive mode must be set to one of the following modes: Fax Only, Fax/Tel Auto Sw, or Ans Machine. If it is set for Answering Machine, be sure the machine is connected to the fax, turned on, and contains a recorded outgoing message.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 24, 2008 | Canon FAX-JX200
Invalid number
Fax machines do not work well or at all on digital lines. They are designed for analog lines, like the standard phone company line. You may have to install a dedicated fax line from your tel. company.
Jun 11, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Assa1875@sbcglobal.net
The error is a communication error. Either the tel line is noisy or the signal too weak. The problem lies outside the machine, and the machine can only identify the global problem not the root cause. You may want to call your Panasonic Tech to check the line condition and tweak the line settings, but other than that, you are at the mercy of your sending party or the tel line company.
Oct 26, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Sending and receiving problems
Where the telephone line comes in from the wall, make sure that it is plugged in the "line" or "wall" port. There is probably another port call "tel" or "acc". If the line is plugged into that port you will still get a dial tone but you are not connected to the fax's modem. You hope that's it. Ed
May 15, 2007 | Canon FaxPhone L75 Plain Paper Laser
Panasonic Workio DP-190 Multifunction Laser Printer Logo
29 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
