Question about MSI K9A2 Platinum Motherboard - AMD790FX, Socket AM2+, ATX, Audio, PCI Express 2.0, Gigabit LAN, S
Mcp61pm-am motherboard need to reflash bios - MSI K9A2 Platinum Motherboard - AMD790FX, Socket AM2+, ATX, Audio, PCI Express 2.0, Gigabit LAN, S
ECS MCP61PM-GM
Lan card Intel Lakeport-G i945G / Intel 82801GB ICH7 I am receving audio voice
Feb 06, 2014 | Computers & Internet
How to recover from failed bios update attempt.
You need to hope that you haven't "Bricked" your motherboard. If the update has failed then you may need to replace either your BIOS chip(if you can find the exact match for your board), attempt to reflash the bios again or replace the motherboard.
Aug 12, 2013 | Alienware Area-51 M15x Intel Motherboard...
I have an HT2000 MCP61PM-AM Rev:1.0A motherboard
It looks like its doing what we call PXE boot. This usually do not happen on manufactured machines unless your an IT personal in a large business.
I suggest that you access your bios and see if it is able to detect the harddrive. Also check the boot priority and make sure that the hard drive is set first.
Dec 19, 2012 | Computers & Internet
Download manual for hp pn 5188 7687
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle GL8E motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle2 GL8E motherboard,
http://www.algogo.com/store/products/ECS-HP-MCP61PM%252dHM-Nettle2%252dGL8E-6150SE-AM2-Motherboard.html
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle3 GL8E motherboard,
http://www.amazon.com/ECS-MCP61PM-HM-Nettle3-GL8E-6150SE-Motherboard/dp/B0045X6N1S
Which one is it?
Oct 24, 2011 | Computers & Internet
Can this motherboard handle an am2+ socket? MCP61PM-GM
YES, AM2 processors will work on AM2+ motherboards and AM2+ processors will work on AM2 motherboards. However, the operation of AM2+ processors on AM2 motherboards will be limited to the specifications of Socket AM2 (1 GHz HyperTransport 2.0, and one power plane for both cores and the IMC). This is taken from wikipedia
Aug 05, 2011 | Gateway MCP61PM-GM (4006254R) Motherboard
Have a motherboard in my computer that stopped working. It is MCP61PM-HM 2.2. I ordered a new motherboard only to find out that the one I ordered was MCP61PM-HM 1.0B. My question is are they compatible?
Seems like the 2.2 is a new version. It supports a
  • Phenom with Quad Core technology (AM2+) up to 9600 (up to 95 watt)
  • The link below has the specs of your original MOBO...
    http://www.softunique.com/ECS-MCP61PM-HM-Nettle3-GL8E-Motherboard-HP-ver-22-MCP61PM-HM-V22.htm
    Here are the 1.0B specs:
    MCP61PM-HM REV:1.0B SOCKET AM2 MOTHERBOARD
    Motherboard description Motherboard manufacturer's name: ECS MCP61PM-HM
    HP/Compaq name: Nettle-GL8E
    CPU/Processor Socket: AM2
    Supports the following processors:
    Athlon 64 X2 with Dual Core technology up to 5600+ (up to 89 watt)
    Athlon 64 less than 4000+
    Sempron less than 4000+
    Front-side bus (FSB) 2000MT/s (2.0 GT/s)
    Chipset NVIDIA GeForce 6150SE nForce 430
    BIOS features System BIOS core brand: Award
    Keyboard combination to used to enter BIOS: F10
    Form factor Micro-ATX: 9.6 in X 9.6 in
    Memory Dual channel memory architecture
    Four 240-pin DDR2 DIMM sockets
    Supports PC-4200 (533 MHz), PC2-5300 (667 MHz), and PC-6400 (800 MHz) DDR2 DIMMs
    Non-ECC memory only, unbuffered
    supports 2GB DDR2 DIMMs
    Supports up to 8 GB on 64 bit PCs
    Supports up to 4 GB* on 32 bit PCs
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jul 07, 2011 | Computers & Internet
    Need to know the location of the bios chip on a esc g31t-m v1.0 motherboard is it next to the battery? Failed bios flash want to remove bios chip to send in to badflash to have it reflashed.
    Not all BIOS chips are removable. Your board uses a AMI Bios and u can quickly identify it by searching for the AMI symbol or lettering. If the Bios has a seat you can remove it: ttp://www.biosman.com/images/extaction_plcc_points.gif
    If it is soldered on...sorry...u need a new MB.
    But have you tried clearing the bios and then reflashing it?
    Jun 06, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
    I'm looking for a BIOS driver that will allow me
    This is the latest bios for your motherboard. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-63117-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3411762
    Feb 23, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
    Motherboard and BIOS problems
    hello
    good morng
    th m.b is pasword lock
    Jun 04, 2008 | Intel Motherboard
    MSI K9A2 Platinum Motherboard - AMD790FX, Socket AM2+, ATX, Audio, PCI Express 2.0, Gigabit LAN, S Logo
    27 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
