Question about Raypak Pool & Spa
No flow of water
Flow switch light does not come on when call for heat is on.
    Top Expert:
  • Raypak Master
  • 8,673 Answers
Check pressure switch
Posted on Apr 27, 2016
Fl0 code
Flo ? for Flow Error?
That would for any number of reasons that the Flow Switch is not sensing enough water flow to trip the sensor/pressure switch or actual true water flow switch.
Heater will not run or heat, if there is not enough water flowing!
The heater will sense this. So, whatever will restrict or stop sufficient water flow is the problem.
  • Dirty filter
  • Closed valves
  • Not enough water in tub or pool - low water level
  • Clogged pump impeller
  • Clogged baskets:
    • at pump or at skimmers
  • Clog / stopped up plumbing line
And finally, you may have a bad flow switch/sensor
Sep 06, 2014 | Jandy Pool & Spa
Unit will not turn off
If your light stays on after water is shut off, your flow switch is sticking. YOu need to replace the flow switch. If your light shuts off, but the unit continues to heat and trips your tco, then your element is bad and the unit needs replacing.
Dec 18, 2013 | Bosch AE-9.5 PowerStar 1.5 GPM...
Great lakes hottub wont heat up
is the heat indicator light showing on the topside panel? If the pump is running and there is not enough water flow to activate the pressure switch then the heater will not come on.
If the filters are too dirty there may not be enough water flow to activate the pressure switch which sends the power to the heating element.
You just may have a bad heating element.
Jan 24, 2013 | Cars & Trucks
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Hello: My pool heater is reading "FLOW" and there is lots of water. What should I do?
The heater has a flow switch.. this is to make sure that the water is flowing through the heater heat exchanger and keep from burning it up...
These switches go bad... now your heating thinks that there is no water flow, so it will not fire....
Change the flow switch and you'll be working again!!
heatman101
May 14, 2011 | Heating & Cooling
Pilot light won't stay on, and water not being heated. Is it because of the magnetic valve not staying open allowing gas to flow through?
hi
could be gas valve. check that the fan and pump run.if not could be an air flow switch.
hopes this guides you the wright way
Dec 29, 2010 | Bosch & Tankless LP Hot Water Heater
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Pool & Spa Logo
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
