Question about HP LaserJet P3005dn Printer
HP LaserJet P3005 Printer PICKS TWICE FOR 1 PAGE PRINTED
You can hear the solenoid go "click, click" then "click, click" along with the sound of the paper feeding from tray 2.
DosHog
  • 168 Answers
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Posted on Jul 23, 2009
SOURCE: HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Posted on Jul 25, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
Tip
Where to find the manual (pdf) for HP Laserjet P3005 printer
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please Click Here to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the above mentioned link.You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturers website , click on the link below:
Canon USA
Canon Global
HP
Epson
Lexmark
Samsung
Brother
Please rate this tip if you found it useful.
Kind Regards
StephanSA
on Mar 07, 2010 | HP LaserJet P3005 Printer
Getting blank print outs with one base line printed of symboles and letters mixed in Hp laserjet P3005.
The two most common problems that cause this are:
1. bad cabling. Check and make sure cables are properly seated and try a different cable if you have one.
2. wrong or corrupted print driver, try uninstalling and reinstalling the driver for the printer.
Jul 08, 2011 | HP LaserJet P3005n Printer
13.01.00 Jam in Tray 2 error when no jam exists
Check Tay2 paper sensor flag, located at tray2 pick up roller, its its stucked shoot the fault
Mar 24, 2011 | HP LaserJet P3005 Printer
Print both sides using hp laserjet P3005
I assume that printer is perfectly installed and
for both side printing,
go to
contro panner ->printer and faxes->right click on printer->select properties->at bottom click on preferences -> choose "duplex printing".
if you cannot duplex printing here need to install duplex printing.
Mar 04, 2011 | HP LaserJet P3005 Printer
HP P3005 is taking forever to print the first page (20 seconds). If I hook it up to my laptop it works fine (5 seconds at most for the first page)
Go to www.hp.com/#support.
Find the firmware for your printer and download it.
Find the drivers for your printer and download them
Jan 07, 2011 | HP LaserJet P3005 Printer
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
Using hp laserjet p3005n, when I print one page it sends blank pg
Annoying but easy to solve.
Go to the printer's ip address management page from a web browser. Look under the TCP/IP address settings. Click on the advanced selection. Disable the LPD Banner page. That should fix it, if it's not under advanced poke around until you find LPD Banner Page. ;)
Oct 20, 2009 | HP LaserJet P3005n Printer
How to change a fuser on a HP LaserJet P3005
you can download the complete manual here, It is in 2 parts. I have downloaded the manual to my computer. The Fuser replacemant starts on page 101 of the first part of the manual. You may have to copy and paste the link into your browser. Also when you click on part 1 or part 2, select "free user" it will go through a 30 sec clock the give you the option to download. It works.
http://printer1.blogspot.com/2008/04/hp-laserjet-p3005-printer-service-and.html
If you have problems I can email you the 3 pages you need.
Joe
Please remember to rate Techs who assist you for free :)
Oct 08, 2008 | HP Office Equipment & Supplies
HP LaserJet P3005dn Printer Logo
20 people viewed this question
Seeker5211
Seeker5211
