Question about Plumbing
Honeywell 4073A orange wire has a residual voltage
The worcester bosch boiler relay keeps energising due to the residual voltage when it should be off. Whats causing the problem if a .47UF capacitor collapse the residual voltage?
melnavz
  • 1226 Answers
SOURCE: Bosch Worcester 24i Boiler
Hello MisNicey!
soory to tell you that you stuff needed a serious troubleshooting in each parts and the repair tech or the service tech in your area can torubleshoot in person. since i am far from your location. melnavz
Posted on Mar 17, 2008
SOURCE: Faulty Worcester boiler
we have a worcester24i rsf boiler installed in our mobile home buy the the water temperature seems locked in at a certain temperatutr any idea how we can change this
Posted on Oct 20, 2008
  • 70 Answers
SOURCE: Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Posted on Jan 16, 2009
jan mczeal
  • 632 Answers
SOURCE: pump in boiler (worcester 24I)keeps stopping
Electric motors are always equipped with a magnetic starter, composed of a magnetic contactor and an overload relay. It protects the motor from burning out when the current drawn exceeds the setting of the overload relay by cutting the power supply.
Furthermore, motors draw more current during starting and draws even more when the load driven is heavy.
Check the following for early prevention of burning out of the motor windings:
  1. Motor windings
  2. Motor temperature
  3. Line current
  4. Motor noise
  5. Load
The usual cause in the rise of motor temperature, line current and noise is the wearing out of the motor bearings. When the bearings wear out, the motor has difficulty in driving the load and draws more current and temperature rises or the motor rotor touches the stator and causes a grinding effect that produces the noise. When the motor always stops, replace the motor bearings and check continuity of the motor terminals with its body. There should be no continuity between the motor body and its terminals, otherwise rewinding is necessary. In your case check the pump impeller for any obstruction.
Note: Continuity test is done using an ohmmeter. With continuity means zero resistance. No continuity means infinite resistance. You may actually need the help of a qualified electrician.
Posted on Aug 23, 2009
SOURCE: My Worcester Bosch 35cdi boiler
35 cdi worcester combi about 3 years old,heating not working,hot water works fine.It's been serviced not long ago.Room stat turned up and trv's ,but boiler want fire up,there's power to the boiler and the room stat the built in time clock is switched to on, but still nothing. do you think it could be the diverter valve, when i got there it was flashing SE which mean's it needs a service,cleaned the heat exchanger and burner with the proper worceter brush etc then re set boiler with technical, they also said it could be the built in clock and told me to disconect it, and just use the heating stat to control it.It still want fire.
Posted on Oct 09, 2009
Operating worcester bosch 240 gas boiler
Control systems operate on a much lower voltage than the boiler. You should be able to put any kind of thermostat in for it. Just be sure of the wiring when doing it. If its a line voltage stat, I'll need more information to advise correctly.
Nov 15, 2013 | Heating & Cooling
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical Support department will be able to help. Their number is 0844 892 3366 - they're open 6 days a week and on average answer calls within 20 second. If you want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
May 13, 2010 | Bosch Water Heaters
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
May 21, 2008 | Honeywell Heating & Cooling
Plumbing Logo
27 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
