Question about Ovens
Whirlpool electronic oven model rs675pxyh doesn't heat up
3 Suggested Answers
SOURCE: whirlpool oven heating element
what are the meanings of gas marks,what is suitable for making pizza
Posted on Jan 22, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
My digital display is not working on my Whirlpool Super Capacity 465
Your problem is most likely the main circuit board for the control panel. That is really the brains for the oven. Ovens are funny things to put electronics in. Electronics do not like heat and what use is an oven that doesn't get hot. I have replaced several of these boards in the recent past and that is what you are most probably going to need to do. Should be an easy replacement. Just be careful removing and replacing the connectors. Some are very fragile (not a good thing to engineer in for a consumer product). I would recommend that you get the model number from the door tag and call one of the appliance replacement companies or Sears for a replacement control board. I would remove the original and make sure that you are ordering the right part number. Manufacturers have a bad habit of switching control boards mid production year, so you could end up with a replacement that will not work.
Aug 02, 2012 | Whirlpool Ovens
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
Only preheats doesn't reach temp
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 09, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont heat
There is a temperature activated thermostat (TOD) that is located on the back of the oven that would explain the problem you are having. The part can be checked with an ohmmeter and should read 0 resistance if it is good. The part number is 9759243 if your model number in the description is accurate (RBS245PDS)
May 04, 2010 | Whirlpool RBS245PDS Electric Single Oven
Jun 04, 2009 | Whirlpool RBS275PD Electric Single Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Whirlpool electric oven won't shut off
It sounds like the electronics has failed and you may get stuck buying a replacement board. Such is progress . . .
Sep 09, 2008 | Whirlpool RBS275PD Electric Single Oven
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
