Astroplasma 250 No Arc, power switch is on and good air flow present on unit
5 Suggested Answers
SOURCE: Laars LX 250-L won't fire up
It was the water flow swith not making all the way. I temporarily jumped it out until I get a new one.
Thanks Ron
Posted on Jun 14, 2009
  • 23 Answers
SOURCE: unstable arc..Millermatic 250. arc not steady
Your windings inside are aluminum, they may have loosened up where the positive lead hooks on to the transformer inside.
I had a miller and the wire melted there, you can re-loop the wire and re-fasten it if it melted short enough if this is infact the the problem when you take the cover off..
Posted on Dec 25, 2009
  • 74 Answers
SOURCE: Not very good air flow. Filters clean evap clean.
head is a bit high air temp ok for a retun air temp of 68-63 wrong fan speed ?
Posted on Jun 17, 2010
  • 1156 Answers
SOURCE: Whynter Portable Air Conditioner Model:
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Posted on Aug 18, 2011
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
Installed new 250 unit today, getting error code IF, Gas is on, gas valve in front panel is open, unit grounded, gas feed line necked down to 3/4 npt at shut-off valve, tried to increase gas pressure 1...
Did you bleed the gas line of air? In a nw installation it is not uncommon to sit there 20-30 seconds with the gas line union open and the shutoff open to get all the air out and a good flow of gas present. If that doesn't work post a comment with what else happens.
John
May 29, 2011 | Hayward 250fdn Low Nox Nat Gas Swimming...
Whirlpool washer AWM 5060. First I set all desire knobs, put on switch to start the machine, then waited for a while, sounded the machine try to work but it won't.
You must start from the begining to check on the inlet valve and the flow of water to the drum. If the flow is not present check or change valve if the power is present. However if water flows well then check the voltage to the motor is the trigger/switching comes from the controller unit. If absent the controller unit needs a check. If present the motor is faulty. If so the motor starter capacitor is faulty. Look to find this capacitor and change, If the motor is humming this is for sure.
Hope my tip helps.
Aug 24, 2010 | Washing Machines
LG 250 Volt, 18000 btu window air conditioner. Tested power on the outlet, and that is fine...but will not power up the unit. Have already tried the reset and test buttons, still nothing. Any help would be...
Take cover off of electrical compartment, locate power on off switch, see if you have proper voltage before and after switch, if power is present locate thermostat, check the same way, also look for burnt wiring, Good luck.
Mar 04, 2010 | LG Heating & Cooling
Put new in line fuel filter, but will not fill filter up with gravity flow. needs air to get the fuel flowing. is there a special filter to use on this?
The Lincoln Gxt 250 is supposed to have an electric fuel pump. Check to ensure the fuel pump is working correctly. Most of the inline filters I deal with dont fill up. There is always a good size amount of air present in them even during operation. I know it doesn't make sense, but they do work.
Jan 13, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Thanks Ron
Jun 13, 2009 | Heating & Cooling
No power to the cutting torch when the trigger is pressed
check to make sure all torch parts are in good shape and is put in correctly
Mar 11, 2009 | Welding Tools
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
