Question about Maytag Sovereign 60 Side by Side Refrigerator
How much does it. Cost to change the augur motor
No ice
I have a Kenmore 106.56163500 that the ice dispenser is not working. I have replaced the ice auger motor. When you depress the ice door lever nothing happens. What next?
The new augur motor is not being energized. Check the circuitry that feeds it power and you will find the source of the issue.
Mar 16, 2017 | Kenmore Refrigerators
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
My ice maker does not despence ice
Apr 07, 2011 | Refrigerators
Ice maker dispenser is not functioning (crushed or cubed), Ice maker makes ice but does not dispense, motor seems to be frozen. Kenmore Elite 106.57703701 model refrigerator
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Dec 01, 2010 | Refrigerators
I have a Frigidaire Gallery Model FRS22XGCD. I am
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Jan 26, 2010 | Refrigerators
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice is not turned by motor mechanism to dispense ice
The motor is behind the ice bin. Remove the ice bin and see if the motor will turn with out the load of the bin. If it will see if you can turn the augur in the bin by hand. It could be locked up by ice in the crusher or tunnel.
If the motor doesn't turn, test it to see if it gets voltage when you depress the switch. If it gets voltage and doesn't turn it's bad. It could also be two weak to turn a load.
Aug 15, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker drawer wont go back in? Metal arm(?) in back of drawer preventing it
I think it may be the augur turner thing that need to be lined up with the augur in the ice bin. Use your hand and reach into the ice bin and turn it by hand till the bin will slide on back.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Sovereign 60 Side by Side Refrigerator Logo
15 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
