Replaced battery-scale shows 1888 then 000 then blank. holding on button shows E
SOURCE: Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
SOURCE: The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
SOURCE: The Homedics SC 380 scale said low battery. After
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
SOURCE: I dropped the box holding
Sorry there is no reet button. Make sure the battery contacts are still making good contact. If so try to calibrate the balance. If that does not work the balance should be replaced.
SOURCE: salter 1200 wall scales and
It is the internal problem with display unit.Just open the case check for loose connection to the display board.Clean the socket and place it tight again.If still the problem persist you have to replace the socket cable.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
