Question about Lexmark X75 All-In-One InkJet Printer
Lxbbprp dll error - Lexmark X75 All-In-One InkJet Printer
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Can not load library lxbbprp.dll using
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Posted on Sep 27, 2010
Theres A Problem of My Computer How To Fix MY Computer The Eror Name is iertutil.dll Thats My Problem Eror
Iertutil.dll Error MessagesThere are several different ways that iertutil.dll errors can show up on your computer. Here are some of the more common ways that you might see iertutil.dll errors:
  • "Iertutil.dll Not Found"
  • "This application failed to start because iertutil.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\iertutil.dll"
  • "The file iertutil.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: iertutil.dll. Please install [APPLICATION] again."
Iertutil.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the iertutil.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Iertutil.dll ErrorsIertutil.dll errors are caused by situations that lead to the removal or corruption of the iertutil DLL file.
In some cases, iertutil.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Iertutil.dll ErrorsImportant: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source.Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  1. Restore iertutil.dll from the Recycle Bin. The easiest possible cause of a "missing" iertutil.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted iertutil.dll but you've already emptied the Recycle Bin, you may be able to recover iertutil.dll with a free file recovery program.
    Important: Recovering a deleted copy of iertutil.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some iertutil.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the iertutil.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the iertutil.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the iertutil.dll file. If the iertutil.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the iertutil.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to iertutil.dll. If, for example, you're receiving a "The file iertutil.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The iertutil.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if iertutil.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the iertutil.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The iertutil.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause iertutil.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual iertutil.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair iertutil.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid iertutil.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the iertutil.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the iertutil.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any iertutil.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Any doubts you can contact a technician through the website
www.thebestpcdoctor.com
Toll Free: 877 407 8229
Aug 11, 2011 | Microsoft Windows 7 Ultimate for PC
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Clkern.dll was loaded,but the dll register server entry point was not found.this file can not be registered
http://www.fix-all-dll-errors.com/clkern.dll/
Once you go to the above link click "Fix dll errors now" button,
it will register the dll file for you.
Dec 29, 2010 | Car Audio & Video
I've been getting an error message: sysenv.dll missing
Hi friends,
"The file sysutil.dll is missing."
"Cannot start Metamail. A required component is missing: sysutil.dll. Please install the application again."
sysutil.dll error notifications may appear while using or installing certain programs, when Windows startup or even shutdown. sysutil.dll errors are caused by situations that lead to the removal or corruption of the sysutil.dll. In some cases, those errors could indicate mostly a registry problem, a virus or malware issue.
to Fix Sysutil.dll Errors
The sysutil.dll error message could apply to any program or system that might utilize the file on any of Microsofts operating systems including Windows XP, Windows 7, Windows Vista, and Windows 2000.
You can fix a sysutil.dll error and there are many ways to do it. A registry cleaner program can help by removing invalid sysutil.dll registry entries that might be causing the DLL error. The below utility is without a doubt the best one out there at the moment.
> Click Here http://filehippo.com/download_ccleaner/
Let me know if any further clarification is required. Hope it will help! Dont forget to rate the solution!!
Dec 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
How to install msvcp90.dll
hi,
http://www.fix-all-dll-errors.com/msvcp90.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Dec 17, 2010 | Microsoft Windows XP Professional SP3 Full...
Can not load library lxbbprp.dll using defaults error 126
Sep 27, 2010 | Lexmark X75 All-In-One InkJet Printer
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
Mar 04, 2009 | Computers & Internet
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Trouble with slbcsp.dll and sccbase.dll
http://www.fix-all-dll-errors.com/slbcsp.dll/
http://www.fix-all-dll-errors.com/sccbase.dll/
This is the best place to get dll problems solved.
Just follow the link given above and click the button "Fix dll errors now" and you are through.
Jan 02, 2008 | Computers & Internet
Prison tycoon 3
hi,
http://www.fix-all-dll-errors.com/d3dx9_25.dll/
u can go to this site...this will help in case of missing or download dll's or errors in dll's..!!
Dec 15, 2007 | Computers & Internet
Lexmark X75 All-In-One InkJet Printer Logo
12 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
