Question about Samsung WF328AAW Front Load Washer
Wire hoop retainer broke in washing machine
Wire hoop retainer broke at location where one end of hoop attaches to spring. hoop retainer was coming out of washer when I open door, so I removed it completely. Now the washer leaks, I repaired the hoop by bending the end and reattaching to the spring, I also hundred mile an hour taped the end so that the sharp point could not damage the rubber seal. can I reinstall this myself ? only lost about 1.5 cm in the length of the wire and thought the spring would make up for the difference in length.
  • 1294 Answers
SOURCE: Pulled the handle to early to open the 7kg front
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Try these sites for spares:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: The seal around the door
The spring encircles the tub - and holds the seal (bellow) in place.
Very difficult to replace.... here is a tip for another machine that will be similar....
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Posted on Feb 17, 2010
  • 662 Answers
SOURCE: The smell that comes from this machine is
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Posted on Jun 20, 2010
  • 298 Answers
SOURCE: How do I remove and
you can go to applinancerepairplanet.vstore.ca for a sevice manual on this to help you in this mater.
Posted on Dec 15, 2010
SOURCE: Washer is leaking from seal around door found a
The spring go's to a wire that snaps around the outside of the gasket. It will be in a grove and hard to find. The spring will hook between the two ends of the hoop wire. Good luck it toke 4 hands to get mine back on.
Posted on Jan 13, 2011
When I go to wash - the normal/casual button is flashing right away - then a dL code comes up then F and it beaps i know before this i was moving around hanging clothes and probably accidently hit the...
fdl = Door Lock Failure
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code dl F comes up on whirlpool duet washing machine
1. Unplug washer.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I get that metal loop around the rubber gasket at the door? It is metal wire with a spring.
Take a flat bladed screwdriver or similar tool then insert it to where the retainer spring connects to the wire hoop at the bottom of the door seal and pull the retainer forward and then off the perimeter of the boot. You may also use a pair of needle-nose pliers to grasp and pull the assembly at the location shown below.
Reinstall the spring and wire hoop assembly by starting at the top then working simultaneously around on both sides going to the bottom of the door seal
Aug 18, 2010 | Kenmore Elite 45986 Front Load Washer
Frontload washing machine made by whirlpool
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^&
Jul 09, 2010 | Whirlpool GHW9400SU Front Load Stacked...
My washer front load rubber at the door has pulled away and the wire with spring has come out. the rubber is not torn and i put it back in but i dont know were the wire gos
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 29, 2009 | Kenmore Elite 45986 Front Load Washer
Ring around the seal where does it go?
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimiter of the seal where it attaches to the door frame, is a small groove. The wire hoop inserts into that groove to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
Dec 09, 2009 | Kenmore Elite 45986 Front Load Washer
Simpson Washing Machine -showing df error
1. Unplug washer.
Aug 22, 2009 | Washing Machines
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Metal ring fell off
If you are talking about a small metal hoop with a spring on one end, it is the outer bellow retaining clamp. The bellow is the rubber door seal. The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If this is not the spring you are talking about, please post back and elaborate a bit more on what the part looks like to see if I can assist you better. (i.e., size, dimension, where you found the part, etc.)
I hope you find this information helpful.
Jun 30, 2009 | GE Energy Star WCVH6260F Front Load Washer
Kenmore HE2 won't finish spin cycle
1. Unplug washer.
Feb 28, 2009 | Kenmore HE2 Plus Front Load Washer
Samsung WF328AAW Front Load Washer Logo
14 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
