Question about GE 106585 Upright Vacuum
Air filter on side of vacuum keeps falling off 106575 model #
Where do the filters go?
You didn't state what model so I can't answer where your filters go. Most vacuums have 2 or 3 filters that need cleaned frequently and replaced when they become restricted. Air must pass from the nozzle at the floor through the dirt cup or bag and filters and through the motor to keep the motor cool, then exit the vacuum back into your home. Clogged filters will shorten the life of the motor and your vacuum won't have near as much suction and airflow. If your vacuum is bagless You most likely have one or two filters filtering the air between the dirt cup and the motor intake to keep dirt and grit from being sucked into the motor which will cause premature failure. There is usually a HEPA filter filtering the air coming out of the motor. if you are seeing a lot of dust on your vacuum that is a sign you may need to replace the filters.
Apr 11, 2016 | Vacuums
How to clean filter
The filter is usually replaced or washed.
Mar 03, 2015 | Filter Vacuums
I can't get the filter to stay in after cleaning
Hi Patty, it's Jack at Dyson.
DC59 Motorhead's pre-filter is engineered to easy to remove for its monthly wash, but should also stay in place securely once it's replaced. In use, the filter will be held in place by the vacuum's powerful suction. When carrying the vacuum from room to room, we'd recommend keeping the machine horizontal, and to avoid carrying it upside down or vertically. It's also worth checking that the black rubber seal itself is clean and correctly positioned.
If the issue continues, I would encourage you to contact our experts directly so we can provide further assistance. You can reach us by calling 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Jan 31, 2015 | Dyson DC59 Motorhead Bagless Cordless...
Can not get filters
While you are looking for a new filter, you could do this(as written in the instruction manual):
1. Hold the HEPA filter
by the edges and vigorously
"TapClean" the HEPA Filter
dirty side down on a hard,
flat surface until no more
dust is observed falling out
from between the pleats of
the filter.
2.
We recommend washing the HEPA filter
once a month or when suction
appears to be reduced. Let the HEPA
filter air dry completely for 24 hours.
3. Rinse the non-woven pre-filter and let
it air dry completely for 24 hours.
4. Insert the non-woven pre-filter.
5. Reinstall the HEPA filter in the
vacuum.
Have a good day.
GB
Nov 06, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
Filter Queen Powerhead Not Working
is it the part where the hose connects to the wand or is where the wand connects to the power head? and what side keeps falling out. it sounds to me that its either a hose or a wand issue. unfortunatly the cord itself cannot be replaced and if the problem is a worn out connector in the hose which is possible it would require a replacement hose and if it is on the wand end it would require a new wand. either are fairly cheep on ebay. or you can possibly find one used at a local vacuum dealer. dont buy new. save yourself some money if possible.
Jul 22, 2008 | Filter Queen Majestic Canister Vacuum
How often should I change a hoover empower filter?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=545652
Generic problem for all Vacuums
How often should I change?
Posted by jdl185 on Apr 25, 2008
How often should I change a Hoover Empower filter?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on what type of filter it is, the suggested change for a filter is every 6 months to one year if it is a cartridge filter or HEPA filter, if it is a filter that can be vacuumed off or it might be a washable filter – you can clean it that way until the filter starts to fall apart – then @ that time you would want to replace it @ that time. Please check with you local vac dealer. Filters
It's important to replace your vacuum filter or HEPA filter regularly to keep your Hoover vacuum working best. Not only will this increase the life of your vacuum, it will also keep unwanted dust, dirt and allergens out of the air. Keep your home Hoover clean with genuine Hoover filters.
So If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Series6500SR
Check the air filter which is at the air output (blower) part of the canister, under the part where the attachments are stored. Also, I know how to disassemble, but the air filter is the likely problem.
Dec 12, 2007 | Electrolux Epic 6500 Vacuum
I need a "Bearing Assembly" for roller brush 61445-1,I Have a GE 106575
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
Dec 08, 2007 | GE 106585 Upright Vacuum
GE 106585 Upright Vacuum Logo
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
T bone 1963
Are you a GE Vacuum Expert? Answer questions, earn points and help others
